Home > In Car Electronics > obdII and earth
Page 2 of 2 <12
munch90
starting is no different with or without
personally I never bothered all though winter with then
of course depends on outside temp , but down south I never needed them even on coldest winter day
as you know its a transit engine , there was a problem with glowplug wiring burning out on the transit and the fix was just the wire and leave it , never ever had anyone say they had starting problems and seen hundreds of them with no plugs working
one reason why I done it was because of the wire burning out , and put a small switch on front of seat box so if it was really cold I can just set switch for plugs to work as normal
Post #432105 19th Jun 2015 10:04am
Caterham
M90,
I've suggested stuff in the past which others have thought ridiculous.......
Well this time I'm thinking it's ridiculous but hoping you're gonna tell it's normal......
I put one of them aux outlets in the back wired off that 'spare' wire behind the speaker trim piece.
And for a long time now I've used it for my sub woofer as a temp installation? Unplugged it tonight and things seemed immediately better.....could it be? Could it by chance have any impact on the rear brake lights / ecm / clutch switch???
The aux outlet was the sole + and - for the sub. And was a poor connection at the as the sub isn't secured?
Will test for the next few days?
Post #432203 19th Jun 2015 5:00pm
munch90
Cant see how they could be any linked at all
Post #432204 19th Jun 2015 5:03pm
munch90
Caterham are you disconnecting the battery each time you touch the electrics ?
Post #432301 20th Jun 2015 8:11am
Caterham
in a word no.
I presume pulling the sub out of the aux outlet wouldn't be a problem?
and disconnecting / reconnecting the switch on the side of the transfer box was while the ignition was off so again I'm assuming this wouldn't have been a problem either?
to my mind there's a poor connection / earth fault or similar relating to the clutch switch and / or the hi-lo for the revs to have done what they did last night?
I'm more inclined to think it's the hi-lo as it might explain the problem in the past where I've pulled off the drive first thing in the morning at it's felt like the throttle pedal has died - perhaps it was jumping into the low response mode associated with selecting lo range? also the sensation of loosing power while cruising at a steady speed - my automatic reaction being to remove foot from accelerator and re-apply (seems to fix it) - hmmm that make me wonder it could be the accelerator potentiometer - but that wouldn't explain the tick over speed not increasing in hi - lo?
so back to the hi-lo switch and clutch switch or power feeds to them?
Big Cry Thumbs Up
Post #432314 20th Jun 2015 9:38am
Page 2 of 2 <12
