Home > Puma (Tdci) > How much slack in the rear drive flanges is acceptable?
carrotbay
United Kingdom 2008 Defender 110 BMW M57 3.0 Diesel XS CSW Auto Santorini Black
I seem to be on a constant quest to reduce the slack in my 110s drivetrain.
How much slack is acceptable in the rear drive flanges?
Here's what I have now even though I changed the flanges about 10k miles ago
https://youtu.be/P1gNuZoN2pQ
https://youtu.be/0FpDXBvCo1A 2008 Defender 110 XS SW - M57N2 / 8HP70X
Post #432172 19th Jun 2015 1:33pm
tomdaprince
Netherlands 2007 Defender 90 Puma 2.4 HT Tonga Green
The first vid is to much play. Ideally there is no play what so ever as a little play will result in major movement in very little time! The second video you see the diff play which is absolutely fine.
If you have this kind of play after 10k you might wanna go a little easy on the left/right foot action. Another solution would be switching to HD halfshafts and flanges which are way less prone to play.
Post #432186 19th Jun 2015 3:02pm
taazzukcb
United Kingdom 2004 Defender 110 Td5 DCPU Stornoway Grey
The HD flanges are indeed stronger, but I personally like these being a weak point. Hopefully you'll strip a flange before you break a half shaft / CV when off-road.
If you have proper lockers and HD half shafts etc though, you'd probably be safe with the HD flanges!
Post #432187 19th Jun 2015 3:04pm
taazzukcb
But yes, first vid is a little more play than you'd expect for a recent job. Were your replaced items OEM and did you slather them in plenty and plenty of grease?
EDIT:
As to diff play, that's far less than mine Laughing Whistle
Post #432188 19th Jun 2015 3:05pm
munch90
pack them with grease , then they will wear less
when defender new ive always packed with grease and never had to change one
Post #432193 19th Jun 2015 3:57pm
carrotbay
The replacements were not genuine and had a small amount of slack in them from the start, but well greased. I think I'll try some Ashcroft HD flanges and hopefully also get a much better fit to begin with. Ideally I'd like to fit some half shafts with integral flanges .. But which ones?
(and yes, I am fairly heavy footed which isn't going to be helping much! Whistle) 2008 Defender 110 XS SW - M57N2 / 8HP70X
Post #432303 20th Jun 2015 8:40am
taazzukcb
I'd personally get some OEM flanges and grease them up.
The only integrated option I think are the old OEM items. Dont think there's any aftermarket.
Post #432342 20th Jun 2015 11:13am
