Home > Maintenance & Modifications > 2ND ROW SEAT SPACE EXTENSION SETS - EXMOOR/HOFELE
smb
Hi everyone,
Ive done a search , but cannot find any other post so has anyone installed these brackets to reposition the second row of seats in a 110 or 90?
Thanks.
http://www.exmoortrim.co.uk/store/hofele/l...etail.html
Post #431922 18th Jun 2015 4:14pm
Matt110
Very interested in this, hadn't realised they existed. My family are all over 6', what I need to do is move the rear seats back as first and foremost priority, then down as the second priority! These look like increased height at the same front/back position?
Post #431933 18th Jun 2015 5:10pm
smb
I don't think they lift the back up. I just think as there are four brackets they just go under the front legs which if they do will increase the rake angle and increase the height of the front.
I don't know for sure though
Post #431935 18th Jun 2015 5:14pm
It certainly looks as though that's all they do - tilt the whiole seat structure backwards slightly so that your legs hang down straighter and hence create the illusion of more legroom.
I suspect that they can only be used in an SW or USW and will not fit in a double-cab since there is insufficient clearance between the seatback and the back of the cab.
I wonder if they actually make the "sitting experience" more comfortable!
Post #431943 18th Jun 2015 5:28pm
Rosco
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Montalcino Red
I got all excited when I saw this as the little 'uns are kicking the bejesus out of the back of my seat, so moving the 2nd row back would be a bit of a God send. But alas it seems just to change the angle of the dangle 2007 - Stornoway Grey 90 XS SW - Gone
2002 - Black Discovery II - Gone
2014 - Montalcino Red 110 XS SW
Post #431971 18th Jun 2015 7:20pm
Matt110
You could always go to twin singles in the rear and move them back on custom mounts? That's my only way out I think if I want to get four adults in comfortably for long distances. Strangely the biggest issue isn't actually leg room for me, its how high the head of the occupant is, you have to stop down to see out the side windows. My brothers about to take the seats out the back of his 130dc, just not viable for distance use if you're tall. More room for the fridge and the sub though!! Very Happy
Post #431973 18th Jun 2015 7:25pm
Stiff1
Don't really see how these help with leg room but could be great for another problem, the backs are just too upright. I wonder what angle they give. I think the red line in their diagram is a little ambitious as front is only raise by 2-3cm.
Really wish we could have different recline options on the middle and rearmost seats but if they can't even make the standard front seats go back like in every other car for the last....???
Post #432122 19th Jun 2015 11:21am
Morepower
New Zealand
Just ordered a set, So will post a before and after pic if anybodies interested ?
Tim It doesn't matter how bad it is, It can always get worse...
2013 Bowler 110 (Sold)
2016 Bowler 90 Rally Spec (Sold)
Post #432451 20th Jun 2015 9:51pm
Fullfat
1999 Defender 90 Td5 HT Rioja Red
I would love to see the before and after pictures and your thoughts on if they improve things, my son is 6"6 and is always moaning about the lack of leg room, so I'm keen to find a solution also.
Post #432884 22nd Jun 2015 8:12pm
Morepower
New Zealand
Sorry for the images being on their sides... But I hope this helps..
Post #433611 25th Jun 2015 4:55pm
Fullfat
so what are they like to sit on with these brackets fitted ?
Post #433614 25th Jun 2015 5:57pm
Morepower
New Zealand
Much better... Where as with the original position you feel too upright and there is no support under your legs. With the Seat brackets fitted the backs are at a much better angle and the seat cushion is in a much better place and it supports much more of your legs..
Post #433625 25th Jun 2015 7:21pm
nicks
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Alaska White
ive just fitted some of these, well worth the money. with child seats fitted its gives them more leg room also
Post #434863 30th Jun 2015 6:09pm
Fullfat
Does the bracket kit do both the double and single rear seat? I can see in your picture the single seat seems more upright ?
Post #434881 30th Jun 2015 7:46pm
Morepower
New Zealand
Yes, This was taken so you could see the difference between the before and after..
Post #434995 1st Jul 2015 8:15am
