Home > Maintenance & Modifications > Cargo net |
jackl Member Since: 01 Apr 2015 Location: Northamptonshire Posts: 12 |
So cargo net all fitted, bar a couple of very small tweaks. I have to say it took longer to install then I expected but everything is bolted back to reinforcing bars in the car so should do the job. The nice thing is it takes seconds to remove and can be used to secure things to the roof rack if out and about and spot a bargain.
Since receiving the net, now had additional net made with sheet attached to fix the oztent to the roof. Again this is well made and looks really good. Click image to enlarge Click image to enlarge |
13th Jun 2015 12:15pm |
AndyTunn Member Since: 10 Jan 2015 Location: Auckland Posts: 313 |
Wow that looks neat! What are the bottoms of the webbing "uprights" attached to?
18th Jun 2015 8:36am |
morning all,
The cargo rail was fixed at the top into the roof rail with M8 rivnuts behind the roof lining then bolted through holding the lining in place. The small side pieces of rail bolted through the channel running the length of the car with M6 bolts and reinforcing plates behind. As for the bottom I used the small black anchor plates shown below bolted through the shelf. Click image to enlarge Click image to enlarge The roof net pictures below. Thanks for the comments I am well happy with the finish. Click image to enlarge Click image to enlarge Click image to enlarge |
18th Jun 2015 9:51am |
Now that is outstanding
Just watch some of those metal clamps don't "chatter" on the side rails and rub off the paint. |
18th Jun 2015 10:03am |
The really nice thing on the clamps is the strap runs underneath so only the webbing touches the rack. Although good point I may length one side and tighten the other make sure.
Thanks |
18th Jun 2015 10:15am |
