Home > Puma (Tdci) > MAP sensor - cleaning didn't work
SteveS
England 2009 Defender 110 Puma 2.4 USW Santorini Black
Regarding my earlier post on MAP sensor and uneven acceleration the advice was to clean the sensor - which I've now done. Unfortunately this made no difference to this particular fault. Does anyone have any other ideas as to what might cause the symptoms:
Always when engine cold (but possibly to a slight degree when hot) on light throttle in say 2nd gear the engine power surges and recedes - sort of like a subtle slow kangaroo-ing. Engine is 2.4L TDCi 18 months old - unmodded as far as I know. I think I read that this could be due to the MAP (not MAF??) sensor - Manifold Absolute Pressure? - being faulty or dirty. Am I on the right track or is there another well known problem? Problem less obvious under hard acceleration.
The MAP sensor was tarred up but the problem lies elsewhere
Post #43148 20th Oct 2010 7:51pm
Scallops
Australia
Re: MAP sensor - cleaning didn't work
Well - mine does this exact thing when the EGR valve is bunged up. Had it replaced a while back - totally went away. Started doing it again more recently, so I took it back to LR - they said the 2nd EGR valve was again sticking and replaced it for a 3rd valve and the surging has gone again.
The solution is - short term, new EGR valve, long term - wait for the German bloke on here to come through with the blanking kit and software patch.
Post #43169 21st Oct 2010 4:01am
Naks
It may be worth it to take out the EGR and clean it regularly, say every 10Kkm or so?
Post #43171 21st Oct 2010 6:12am
K9F
Agree totally if you've got the time and inclination....was meaning to do it but LR Assist had to be called and a new EGR Valve fitted under warranty before I found time to do it!
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #43179 21st Oct 2010 7:52am
mse
How hard is getting at the egr on these, ive never really looked. Mike
Post #43181 21st Oct 2010 7:56am
Naks
K9F wrote:
Agree totally if you've got the time and inclination....was meaning to do it but LR Assist had to be called and a new EGR Valve fitted under warranty before I found time to do it! Thumbs Up
Didn't I read somewhere on this forum that LR stealers put some kind of EGR cleaner in your diesel tank when they service the vehicle?
If so, it would make sense to stick a bottle of that stuff regularly, every 5000km or so?
I have been adding 2-stroke oil to my Puma since day 1, theoretically this should mean my EGR is cleaner than just running with diesel. I will ask the stealer to open and clean the EGR at the first service, only got 12Kkm on the clock, so 8Kkm more to go until then.
Post #43182 21st Oct 2010 8:09am
o4dn
France 2009 Defender 90 Puma 2.4 SW Alaska White
I did clean the MAP sensor as well last weekend.
I also ran the EGR cleaning procedure by starting/stopping the engine several times (maybe 5 or 6 times, leaving it running for 30 secs or so in between) and it seems to have improved... Or maybe it's just me Rolling Eyes
Post #43184 21st Oct 2010 8:25am
jlerra
Gibraltar 2007 Defender 90 Puma 2.4 XS CSW Java Black
Map problem?
SteveS,
Try changing/testing the clutch switch on top of the brake master cylinder.
Have a look on page 2 of the Defender2 forum under 'over-revving on changing gear'
Might not be anything to do with map.
Rolling Eyes
el pepe flamenco JLS
'El Pepe Flamenco'
Post #43189 21st Oct 2010 9:57am
BIGFOG
United Kingdom 2009 Defender 110 Puma 2.4 USW Stornoway Grey
Who is the German bloke??
Post #43328 22nd Oct 2010 10:24pm
Scallops
Australia
Red Desert - http://www.defender2.net/forum/topic358-105.html
Post #43340 23rd Oct 2010 2:32am
spudfan
Ireland
You might like to Google DIPETANE FUEL TREATMENT. I got a bottle of the stuff. If it's claims for reduction in waste gases ,including a big reduction in the NOx emissions are true it should go a long way to keeping the EGR valve clean. I have e-mailed them specifically regarding the EGR valve in the Land Rover Defender TDCI 2.4 engine. When I get the reply I will let you know. If it works and if it only needs occasional use it would be o.k Could work out expensive if needed at every fill.
Another product AUTOMAINTAIN fuel system clean and restore is used once every 10,000 miles. It has similar claims. I did contact AUTOMAINTAIN who said that the Fuel System Clean and Restore will keep the EGR valve clean. I can forward you the e-mail if you want it. My main dealer uses Automaintain Profession Oil System Clean and Restore at servicing.That is how I came across Automaintain.
Anyway the Automain Fuel System Clean and Restore would appear to be better value as it is used once every 10,000 miles and it claims to clean the whole exhaust system. Does not take much to do a search on both products and have a read. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #43469 25th Oct 2010 1:29pm
K9F
I use this: Millers at a tad over £9 per bottle somewhat cost effective and that can do a total of 10 tank fills. I find it 'does for me!' Not had any problems since and must admit last time I changed my EGR Valve blank from 12mm down to 10mm blank was not as dirty as previous prior to use!
Thumbs Up
http://www.google.co.uk/imgres?imgurl=http...s%3Disch:1 If you go through life with your head in the sand....all people will see is an ar5e!!
Post #43492 25th Oct 2010 7:00pm
BIGFOG
My Puma drinks the same Millers additive, I get it from Halfords... Wink
Post #43922 29th Oct 2010 10:49pm
