Home > Puma (Tdci) > Water Ingres through..
G4sweep
Germany 2012 Defender 110 Puma 2.2 XS CSW Santorini Black
Hi All,
I was wondering if anyone has experienced the following? Water Ingres into front of vehicle via the foam seal under the windscreen? I can't find any where else where it can be coming in from. Are there any simple fixes / solutions? Did think of sealing with bathroom sealant!
Cheers in advance
Sweep Sweep
2.2 110 XS SW
Gone;
08 D3 XS
BN55 WPV G4 4.4V8 D3.
O7 G4 Mongolian Recce 110 USW
Post #42788 17th Oct 2010 10:46am
jlerra
Gibraltar 2007 Defender 90 Puma 2.4 XS CSW Java Black
leak
Hi,
Try 'Captain Tolly' self seeking sealer from any boating shop.
It is clear and and will seek out leaks.
Great stuff
El pepe flamenco JLS
'El Pepe Flamenco'
Post #42790 17th Oct 2010 11:07am
Grockle
another fix someone did on here awhile ago,loosen the six screen bolts each side of the screen surrond get some one to sit on the front of the roof, then re tighten(dont over tighten them as they will break through the outer covers) are you sure it's not the screen to frame seal leaking our TD5 leaked from that.
good luck 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #42792 17th Oct 2010 11:17am
double cab happy
England 2007 Defender 110 Puma 2.4 DCPU Java Black
need'd my front screen re-sealing to stop the leek.
Post #42795 17th Oct 2010 11:50am
G4sweep
Cheers all I will give the options a shot, many thanks. I'll start with tightening the bolts then go from there!
Thanks again,
Sweep Sweep
2.2 110 XS SW
Gone;
08 D3 XS
Post #42819 17th Oct 2010 6:25pm
PDH
If it's still under warranty then take it in and get the garage to do it, mines going in next week to get this sorted Puma 2.2 90 Stationwagon
Post #42825 17th Oct 2010 7:01pm
PDH
Post #42826 17th Oct 2010 7:02pm
Glynparry25
Also make sure it isn't the door seals. I thought mine was through the windscreen but it turned out to be the door seals Rolling Eyes typical Land Rover.... Water on the left side of the car is caused by a seal on the right side!!
Glyn Sheep
Post #42834 17th Oct 2010 8:06pm
double cab happy
also if its like mine (or fekete's) there will be some rust issues on the inside of the bulkhead, waiting to get that sorted, plus if it is rusty then its 6 years not 3 years warrienty.
Post #42846 17th Oct 2010 9:24pm
mse
Are you sure its the seal...i have painful experience.
New windscreen seal
New windscreen (see above Laughing )
Sealant various places
Wing off - airbox out - reseal
Then there is the foam...but i bet its not coming from there Thumbs Up Mike
Post #43083 19th Oct 2010 10:09pm
Happyoldgit
Water ingress = common problem, so common there's a Defender water ingress manual dedicated to the subject. They had my previous Puma back to replace the seal & door seals ..oh and the TD5 before that, and possibly the TD5 before that. Steve.
Ineos Grenadier Trialmaster but owned numerous Land Rover vehicles of all shapes and sizes over the decades.
Current Defender: A non tarts hand-bagged Puma 110 XS USW.. Now long gone.
http://forums.lr4x4.com
Post #43120 20th Oct 2010 1:28pm
bob neville
Re: Water Ingres through..
G4sweep wrote:
Hi All,
Cheers in advance
Sweep
Yes !
Yeovil LR replaced the foam seal on my 2009 vehicle , apparently they have done a few, and sealed the windscreen correctly. problem solved. Not a simple job to replace as it is a dash out, roof off job.
Bob
Post #43121 20th Oct 2010 2:13pm
G4sweep
Oh Big Cry Well ill have to get out and have nother look to see where its definately coming from then and get me bum in gear Whistle
Thumbs Up Sweep
2.2 110 XS SW
Gone;
08 D3 XS
Post #43133 20th Oct 2010 5:07pm
stevie
I had new window / seal, also put in with silicone. Silicone all over the place, in all the rain channels. New door seals on both front doors helped. The rain was running down the door seal and into the carpets through a crease in the seal. Then had to have the roof re-sealed along the centre joint and the all the roof repainted.
Think the water has stopped coming in now. Although i still think some is getting through the foam seal on the bulk head. The bulk head now has rust on the inside. The vehicle is only 2 years old.
At one point there was that much water getting in the car that it got into the alarm module and caused it to blow. The alarm was an after market fitment and was mounted behind the dash board and mounted to the bulk head. Land Rover had to pick up the bill for £200 to have the module replaced.
Hope you get yours sorted. I now think i ve got a leak on the drivers rear door Rolling Eyes
Post #43710 27th Oct 2010 8:54pm
