![]() | Home > Maintenance & Modifications > Where to buy ACF50 |
Scoobeenut Member Since: 04 Mar 2015 Location: West London Posts: 310 ![]() ![]() ![]() |
As above really, where is the best place to buy and is it aerosol or paint on?
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3677 ![]() ![]() ![]() |
loads on Ebay and Amazon aerosol or pressure pump DEFENDER 90 TDCI XS,
jomara Member Since: 26 Oct 2009 Location: Lanarkshire Posts: 1790 ![]() ![]() ![]() |
Motorcycle dealers are the best bet, I got mine from Ducati Glasgow hen passing
![]() 1971 Bowler Tomcat 88 4.2 V8 Auto 2022 110 D250 XS Edition - GONE 2024 110 D250 X-Dynamic HSE |
Okay thanks to all will check out ebay, mainly seems to be aimed at motorcycles on there or am I looking in the wrong place?
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20967 ![]() ![]() |
Thanks for the link. Do I just spray everywhere or just the likely areas for corrosion?
Hi Scoobeenut
Have a read here, Zag outlines the areas that are best treated with ACF ![]() http://www.defender2.net/forum/topic10467.html 2014 110 2.2TDCi XS Station wagon - GONE 1971 Bowler Tomcat 88 4.2 V8 Auto 2022 110 D250 XS Edition - GONE 2024 110 D250 X-Dynamic HSE |
Mainly likely areas such as door hinges, non SS standard bolt heads under cappings and so on.
It's safe on paint and clear so any over spray is fine but try and avoid it if you can as it isn't the easiest thing get off. |
nitram17 Member Since: 09 Jun 2014 Location: newcastle Posts: 2261 ![]() |
Vote for amazon ![]() |
DEF Member Since: 19 Oct 2014 Location: Gold Coast Posts: 17 ![]() ![]() ![]() |
Or you can check for dealers in your area :
http://learchem.com/distributors.html |
Buy a bottle of liquid and a pressure pump - that way you will be sure to get all the product out. Can't count the number of times I've thrown aerosols out because the propellant has run out but you can feel there's still product in the can. You can also put a bit on a rag and rub down a general area or even paint it into small gaps or areas. ![]() Click image to enlarge |
Cheers supacat have ordered the liquid and pump bottle as you suggested.
couplands Member Since: 31 Aug 2011 Location: Peak District & Cornwall Posts: 1830 ![]() ![]() ![]() |
+1 for the bottle and pump. Lasts a while too.
Cheers Simon |
PumaGreg Member Since: 04 Mar 2009 Location: UK Posts: 80 ![]() ![]() ![]() |
+2 for a pump and bottle. Followed the recommendations on here. Excellent stuff! Greg
Currently: 2013 90 2.2 Puma Base Station Wagon 1991 90 Tdi 2015 Discovery Sport 2.2 |
