Home > In Car Electronics > Standard alpine (XS spec) mic not working?
Jimbob
Wales 2015 Defender 90 Puma 2.2 HT Corris Grey
Hi all, my 15 plate 90s mic has stopped working for the Bluetooth. Anyone had anything similar and it turned out to be something stupid before I take it back to LR? I don't have the radio keys so I can't check for any loose connections or anything so it'll have to go back if that's it but I'm wondering if it's turned off or something stupid before I take it back? Bit of a trek just for a stereo lol 2009 Defender County Hard Top (gone 😞)
1990 200tdi defender off roader
2015 Defender XS Hard Top (awaiting delivery 😄)
Post #430213 11th Jun 2015 1:22pm
Macpaul
United Kingdom 2013 Defender 110 Puma 2.2 USW Loire Blue
I've got a 2013 XS USW with an Alpine head unit that I've had out about 20 times trying to fix a rattle.
Get a pair of reading glasses and a good light. Radio face off. Trim surround off - optional but makes it easier.
If it's the same as mine you can just raise the two tiny little 'cotton bobbin' type fasteners to lift the pin on each side of the radio enough that they clear the open face of the slot of the cage itself.
Sometimes you can lift one, pull the radio slightly forward so it jams, then do the other side. Otherwise pull both sides together once the pins are disengaged from the cage. The bobbins have a recess in the internal face so if you have something sharpish you can use these recesses to pull on.
Bit difficult to explain but easy to do.
Make sure all the connections go back in after. The sub-woofer cables seems to come adrift quite easily when you pull the head unit forward.
Good luck! 2003 Td5 110 Hardtop
Now a 2013 110 USW too.
Post #430227 11th Jun 2015 1:58pm
Jimbob
Ok thanks I'll give that a try, I think I might have an old set of radio keys now thinking about it at my parents garage, I'll have to check. But your method sounds easy enough! Thanks! 2009 Defender County Hard Top (gone 😞)
Post #430255 11th Jun 2015 4:47pm
nosnibod
United Kingdom 1998 Defender 110 300 Tdi SW Bronze Green
I've had the same. It will almost certainly be the microphone plug has popped out of the socket in the back of the radio. It will have probably dropped into the gloom and need fishing out...
As Macpaul says, you don't need radio removal keys - just lift the little bobbins with something like a screwdriver and you can gently work the radio out. Dave
Green Goddess - 1998 Defender 110 300tdi
Post #430277 11th Jun 2015 7:40pm
nitram17
Good luck!
How do you get the trim surround B off..ive removed the radio facia unit and im faced with a wall of black plastic..any pics as i dont want to damage it? are the two pins you are talking about A? at the sides near the bottom?move them up and pull is that what you do?
Post #906059 1st Jun 2021 10:39pm
