![]() | Home > Wheels & Tyres > 35" Tyres |
camelman Member Since: 27 Feb 2013 Location: Peak District Posts: 3411 ![]() ![]() |
I ran 305/70/16 which are 33 x12 inches wide on 16x8s no bother so the width should be ok.
The only thing with 35's is you'll need a lift kit and possibly a better offset so probably ET0 or maybe even more negative ![]() |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8401 ![]() ![]() ![]() |
i have run 12.50s on 8" rims on an off roader. Cheers
takoon Member Since: 16 Oct 2013 Location: central Posts: 48 ![]() ![]() |
No problem, just be aware of when you letting air out for better traction on soft ground, the risk of rip the tyre off the rim is greater. This also depends of wich tyremake you choose ( sidewall stiffness). God luck
![]() -09 Jaguar xk4,2 Portfolio |
