![]() | Home > In Car Electronics > 2014 DEF 90 Tow Wiring Plug |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20788 ![]() ![]() |
Plug and play more or less no hard wiring required.
However, you'll need a genuine towing wiring harness. What type are you trying to fit? |
Rickoz Member Since: 27 Jan 2014 Location: 4000 Posts: 39 ![]() ![]() ![]() |
This (RAA623) wiring kit came with the Land Rover TowBar but no plug & Play as you call it. Is there a Ref No. for that that plug? ![]() Click image to enlarge |
jomara Member Since: 26 Oct 2009 Location: Lanarkshire Posts: 1790 ![]() ![]() ![]() |
Hi Rick
Steve is talking about the genuine LR towing electrics, part number LR005920, you can see this has a straightforward plug in loom ![]() ![]() 1971 Bowler Tomcat 88 4.2 V8 Auto 2022 110 D250 XS Edition - Gone 2024 110 D250 X-Dynamic HSE |
jomara your a champion this answers everything
wyvern Member Since: 14 Dec 2009 Location: Cornwall Posts: 2127 ![]() ![]() ![]() |
if you dont mind fidling you can feed the cable out though the big hole in the cross member to give you a protected female electrical conector - makes the whole set up look better in my opinion....
![]() I used to think that this was for power take off from the engine but have since been told that it is designed for the electrcal connection. (but I will stand to be corrected if wrong!) Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html Elgar -TDCI(Puma) 110XS Dormobile - now sold Devon & Cornwall 4x4 Response - DC126 ![]() |
wyvern
As Jomara suggested that was the kit I was meaning.
It's 12N so assuming that is what you want. ![]() |
custom90steve ta, ![]() |
Excellent.
![]() When fitting or working on I'd recommend a small plastic bag with elastic band around or similar over the plug end when your routing the cable, then you don't have to worry about dirt getting in the plug. Then just whip it off right before plugging into the socket and it'll be perfectly clean with a perfect connection. ![]() |
Davie L Member Since: 04 Sep 2014 Location: Glasgow Posts: 95 ![]() ![]() ![]() |
Does this have a separate fuse in a 08 puma?
Davie |
DavieL there was no fuse holder or fuse with the tow wiring that i got so i'll say No.
Ok I only just started to fit the plug & play tow wiring kit on the Defender, yer slack I know
![]() Is here a trick to fitting the washers & nuts on at the backside of the cross-member? The hole is rather smallish to fit fingers through easily once the cable goes through it too. What am I not thinking of to do the job as well, how to keep the nuts tight & won't vibrate off over time. ![]() ![]() |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17739 ![]() ![]() ![]() |
Your are totally correct! ![]() Designed, but seldom used, for the purpose. |
Well i've tried glueing the nut to the washer then after drying gluing the lot to the backside of the cross-member hmmm nice idea just couldn't get the washer to the cross-member to hold when screw bolt in after drying had to pull the wiring back out to get access to hold the nut so I could remove bolt from it ![]() Anyone that has done it want to shed some light on how you did it at all pwwwease |
