![]() | Home > Puma (Tdci) > Charging problems |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20978 ![]() ![]() |
Just to add to my last post as a possible thing.
Before any work is done at all, disconnect the battery completely for half an hour then reconnect it and see what happens. It might need the whole ECU / system to re-boot and recognise that there is no longer a problem. If nothing else it might be worth trying as sometimes to power off completely for a while then back on will sort it's self out. |
Thomjam Member Since: 07 Jun 2015 Location: Oslo Posts: 6 ![]() ![]() ![]() |
Thank you all. I have talked to the guys at the garage, and we have agreed to replace the new alternator with a new original one, after they have tried all the alternatives you have suggested here. We'll see how that works out...
Make sure they let you know exactly what was the problem.
I will! And I hope it works out. Next step is to replace the ECU, they say. And if it's not that, the ECU is custom made for the car, and would be money out the window
![]() Btw the starter was replaced this Easter, so it has been a few things this winter. i put it on the charm account , can't other than love the Defender, though strange things happen with it. Perfect car in Norway. |
Changing the ECU solved the charging problem. They never found out what the exact problem was. Land Rover...
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17944 ![]() ![]() ![]() |
The alternator is ECU activated on a Puma.
