Home > My Defender > Getting too old for this !!
lohr500
After two days grovelling around under the Defender applying Dinitrol to every nook and cranny, I ache all over and can hardly move Crying or Very sad Just trying some medicine from a cold tin or four to see if that helps.
I took the opportunity at the same time to fit the OE military style steering guard I picked up off eBay, This also got a good coating of Dinitrol inside which hopefully will keep the tin worms away.
After completing the Dinitrol application I then needed to remove all the overspray from the bodywork which led to a full wash and polish.
I will be glad to get back to work tomorrow for a rest. If I can move that is Neutral
Post #429306 7th Jun 2015 7:51pm
LR90XS2011
satisfying aches though DEFENDER 90 TDCI XS,
Post #429308 7th Jun 2015 7:54pm
shaggydog
Looks Great, Love the front grill and badge Thumbs Up Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Self confessed mileage hunter Very Happy
Post #429311 7th Jun 2015 8:00pm
munch90
Drill a small hole at the bottom in each supporting tube on the steering guard and spray some wax inside as the tubes fill up with water over time
Post #429312 7th Jun 2015 8:01pm
lohr500
Great suggestion Munch. Thanks. Hadn't thought of that. I did blather loads of black Dinitrol around and into the flattened ends of the tubes where the guard mounts onto the chassis in an attempt to seal up the ends of the tubes, but holes would be a better option. A quick job one evening this week if the weather is fine.
Post #429314 7th Jun 2015 8:08pm
lohr500
Thanks Shaggydog.
The OE Brunel coloured grill and headlight surrounds just didn't look right to me with the rest of the vehicle in black.
So I went for a more traditional look with the Nakatanenga grill and a cheap set of surrounds spray painted in matte black.
The weathered badge kind of felt right and finished it off.
I'm not a big fan of blinged up Defenders so the grille is as far as I will go. Apart from possibly a set of Sawtooths, or black Boosts to complete the all black look.
Post #429320 7th Jun 2015 8:17pm
