Home > Td5 > Valeo or Genuine clutch and flywheel?
Page 2 of 2 <12
Ronny S
Norway 2006 Defender 110 Td5 XS CSW Zermatt Silver
Do you also change the flywheel bolts?
Think they should be about 40Nm + 90 degrees. Hard to pull the last 90 ...
Ronny S
Post #429012 6th Jun 2015 3:11pm
excossack
I had changed:
All the clutch parts (as listed)
DMF bolts and torqued to correct LR spec (Gen LR bolts)
Plastic clip on the release arm (Gen LR) 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #429013 6th Jun 2015 3:14pm
JWL
I suppose that 177K miles I must resign myself to changing the original clutch.............. one day Whistle
Post #429015 6th Jun 2015 4:17pm
Hufflepuff
My clutch has started slipping at 75k miles, the spiggot bush is squealing in reverse, and there is a rattly sound when idling, perhaps this is what is known at chattering?
Anyway, I need it replaced ASAP as I'm off on holiday in it in a months time.
The local independent has quoted me around £1300 to do the job, including the DMF (oem kit), I just wanted to know if this sounds about the going rate? I'm happy to pay it as I don't have the time to do it myself at the moment, but I was a bit surprised it was this much given the price of the parts. It only took a few hours to it on my old lightweight!
Post #463924 16th Oct 2015 10:56pm
alexatnd
That seems a lot. Think it cost me ~ £800 to h ave mine done on Gertie. Still got the receipt so I'll check tonight
A Santa - 1977 Series 3 - new chassis, tub, disc brakes,SU Carb
Gertie - 1999 110 TD5 - new chassis etc back on road
Effie - 2004 110 TD5 County
Post #464931 20th Oct 2015 1:36pm
Hufflepuff
Thanks Alex. Since booking it in, the car has decided to stop slipping its clutch now - no matter how hard I tried at the weekend. I'm now wondering if oil leaked onto the clutch plate from the crankshaft seal?
I've emailed the garage anyway and they'll take a look when they do the DMF. It will be worth it just for the piece of mind - I don't want it failing on me when expeditioning next month! (even if its only in the dizzy heights of the Welsh mountains Embarassed )
Post #465240 21st Oct 2015 1:08pm
Page 2 of 2 <12
