Home > For Sale & Wanted > Tdci improoved Manifold to turbo gasket
Page 2 of 4 <1234>
big steve
United Kingdom 2015 Defender 90 Puma 2.2 HT Montalcino Red
Fekete you only slag products off any way Iv done sonic not going to worry get on with it 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P
hybrid turbo in build -done ready to fit
ashcroft atb in transfer box
6 speed auto in build
Post #66716 8th Apr 2011 11:25pm
fekete
United Kingdom 2007 Defender 90 Puma 2.4 HT Bonatti Grey
Shut up you Girl... Big Steve grow a spine lad and stop crying.... i never slag any produced off that works ? NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #66720 9th Apr 2011 12:01am
discocuzzy
Easy fellas, Karl you just staggered in from the battlecruiser by any chance? Whistle Thumbs Up You cannot teach stupid people to do clever things
Post #66721 9th Apr 2011 12:05am
fekete
No Steve hes a nob mate Whistle NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #66723 9th Apr 2011 12:08am
cobs
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Cairns Blue
Pete, Big Steve, Andrew S,
Any advice on how to remove the two nuts that hold the oil return pipe onto the turbo - they're right underneath the turbo and impossible to get to
Also of the three nuts that hold the turbo to the exhaust manifold two are easily accesible but what's the best way of getting to the front one which again seems in an impossible position?
Any help greatly appreciated!!!
Post #66758 9th Apr 2011 5:30pm
big steve
spanners and time i used a socket with a bar on 1/4 drive for the little bolts just cracked em undoen then loosened with the extention and fingers
the top of the triangle is a spanner job im a afraid and the other 2 you can get to with a socket and exstension hope this helps
regards steve 2015 2.2 tdci hardtop xs
Post #66808 10th Apr 2011 11:12am
cobs
OK thanks - will have another go when I can psysche myself up
Post #66812 10th Apr 2011 1:37pm
nakatanenga
Germany
Same as Steve states! no special tools, just extra bent fingers Wink WANTED:
SII or SIII in max 1.5k
Post #66849 10th Apr 2011 8:37pm
defender75
2009 Defender 110 Puma 2.4 XS CSW Chawton White
Anyone have a step by step of what to remove and what not to?
Post #88960 13th Sep 2011 8:07pm
chopdogs
Guys
Am thinking of this as a solution to my turbo whistle
Will the turbo have been damaged during the time since it started whistling (at least 1,800 miles ago)?
Thanks
chopdogs
Post #124983 18th Feb 2012 5:42pm
ZeDefender
chopdogs wrote:
Guys
Thanks
chopdogs
Same question from me! First service in May and I've bought the Nak. gasket in preparation. Not sure it will be easy to convince LR Germany to use it under warranty though... Tell someone you love them today because life is short.
Post #125029 18th Feb 2012 8:48pm
We've had experiences of fixing this problem.
We had a customer who drives hard and tows even harder, we removed the turbo and had both flanges skimmed, he still managed to get the 'whistle'.
After admitting he 'abused' his motor... Towing at high speed for hours on end, the final fix was a nak gasket, turbo flange skim and a 'twisted' downpipe, which has a good thick flange, as well as a bracket (de-cat). No problems at all since. QRZ 2e0vpf
Post #125040 18th Feb 2012 9:40pm
Charlie Spitfire
France 2008 Defender 90 Puma 2.4 HT Tonga Green
I have the same problem and I have just bought some Nakatanenga gaskets, I wanted to ask what bearing, if any, changing the exhaust downpipe would have on removing turbo whine at the turbo/manifold flange?
Post #429009 6th Jun 2015 2:57pm
mk1collector
If the down pipe has a thicker flange I presume it's less likely to warp. Ray
My build thread
Post #429025 6th Jun 2015 5:33pm
ZeDefender
The down pipe is on the low-pressure side of the turbo, so I think less likely to warp and scream anyway as it's a lot cooler than the manifold-turbo flange. Fixed mine now by skimming said flange (filing it flat actually - only took an hour). I also don't run it hotter than 600 degrees on the turbo outlet side (= about 750-800 degrees at the inlet = 150 km/h at full pelt)
Thumbs Up Tell someone you love them today because life is short.
Post #429131 7th Jun 2015 6:21am
Page 2 of 4 <1234>
