![]() | Home > Maintenance & Modifications > V8 engine options |
jomara Member Since: 26 Oct 2009 Location: Lanarkshire Posts: 1790 ![]() ![]() ![]() |
Hi Pickles, Twisted are in the process of building a pair of Defenders with LS3 engines
https://fbcdn-photos-a-a.akamaihd.net/hpho...878f00f881 And Urban Truck have their version, the RS with over 500bhp and a push button automatic transmission ![]() The LS3 seems to be getting more common as a transplant ![]() 1971 Bowler Tomcat 88 4.2 V8 Auto 2022 110 D250 XS Edition - GONE 2024 110 D250 X-Dynamic HSE |
Pickles Member Since: 26 May 2013 Location: Melbourne Posts: 3802 ![]() ![]() ![]() |
Yes, the LS3 is a really practical engine. It has a bullet proof bottom end, & it'll take a lot of punishment.
It produces great power & torque, and ya don't have to rev it. And if 300KW is not enough, there are huge amounts of "hot up stuff", cold air intakes, heads, exhaust systems, camshafts etc etc, and perhaps one of the easiest & most effective, superchargers, to get you to 500KW+ easily, if that is your needl Heaps of these running around, mostly in Commodores, in Aus, making 7/800HP+, and could still be driven to Church on Sunday, by a little old lady. Pickles. |
dazzx10r Member Since: 26 Nov 2014 Location: Rotherham Posts: 17 ![]() ![]() ![]() |
Interestingly, the new Wildcats are powered by a supercharged Jaguar V8. It's a good lump, all alloy block you can find them all over the place. http://en.wikipedia.org/wiki/Jaguar_AJ-V8_engine
Fozzauk Member Since: 05 Feb 2014 Location: Derbyshire Posts: 272 ![]() ![]() ![]() |
So I have bitten the bullet and gone for a 4 litre Tvr chimera engine. The 5 litre was double the price and would end causing a lot more work upgrading the whole drivetrain. So more money left in the kitty for other jobs!
Going to have a bash at fitting the puma bulkhead and dash whilst the engine is out. |
So I have now ended up with a 5 litre TVR engine as the breaker couldn't supply me with an ecu for the 4 litre and I got sick of waiting for it! The puma bulkhead and engine are in with just the wiring to complete now.
Does anyone have or know where I can get a loop drawing for the 5litre TVR V8 engine and ECU, I have the puma one for the dash but struggling to find one for the TVR? |
mikeh501 Member Since: 07 Jan 2013 Location: United Kingdom Posts: 1142 ![]() ![]() |
Which ECU is it using? Gems?
I don't think its a GEMS, It has the following info on the ECU "AMR2175 14CUX Land rover 80405"
that would make it a "hotwire" setup i think. im no expert. muddling through my own v8 conversion
need4speed Member Since: 23 Nov 2012 Location: Kilmarnock Posts: 749 ![]() |
In which case do yourself a long term favour by junking it, and using Megasquirt.
I emailed megasquirt last week as they don't list the 5 litre lump and haven't heard back from them yet?
Inigo Member Since: 13 Nov 2011 Location: Kent Posts: 627 ![]() ![]() ![]() |
Have you tried http://www.megasquirt-v8.co.uk/index.php
Nige is very helpful and knows his stuff. Has squirted assorted versions of Rover V8s. |
^^^ what he said ^^^
The fact that it's 5 litre will make no difference. Nige aka Hybrid From Hell over on LR4x4 is very helpful and will sort you out.. ![]() |
Surely the 5 litre will need a different map to to 4 litre?
Ignore that last post, had a more indepth read of the megasquirt thread!
