![]() | Home > Td5 > Chassis swap advice needed |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2770 ![]() ![]() |
I would suggest standard bushes (Genuine parts only) rather than any kind of polybush. Standard springs/shocks is a good shout.
For the bolts just go through the parts catalogue and order the necessary bits from your preferred parts supplier. Or even from your local fixings place, just ensure the grades are correct etc. |
Green Machine Member Since: 19 Nov 2010 Location: North Yorkshire Posts: 1226 ![]() ![]() ![]() |
I recently had my Td5 re-bushed all round and did a lot of research online into various bush options. Came to the conclusion that it was best to stick with genuine / OEM for everything. You can get OEM parts for all the bushes, I think there are a couple of washers that aren't available OEM, so had to buy Genuine for those. 2005 Td5 | 90 Station Wagon | Tonga Green
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10387 ![]() ![]() |
I'm just in the middle of a chassis swap\rebuild, you will find that a lot get snapped/too rusty to replace as you strip it all down...
I'm waiting for bolts right now for the a-frame chassis mounts.. It's what's holding everything up. |
dancerdave Member Since: 14 Mar 2014 Location: N Ireland Posts: 80 ![]() ![]() ![]() |
Post #4287965th Jun 2015 2:22pm I'm just in the middle of a chassis swap\rebuild, you will find that a lot get snapped/too rusty to replace as you strip it all down... I'm waiting for bolts right now for the a-frame chassis mounts.. It's what's holding everything up. Yeah that's what I was thinking, surely someone makes them up in packs |
I wish they did a complete set...I spent hours on the catalogue listing all the separate bolts, washers, nuts etc.. A right nightmare, you'd be surprised what goes pear shaped...Even the bolts that hold the rear damper brackets through the chassis were that rusty, the nuts turned but didn't come loose. So I ordered new brackets, but forgot to order the bolts....
Stupid Land Rovers!! |
Thanks to GREENI that's springs and shocks off the list
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5140 ![]() ![]() ![]() |
Lots of Land Rover Defender 90 Chassis Bolt Kits out there reasonably priced.
For a 90 http://www.a2stainless.co.uk/Land-Rover-De...AFE2X.aspx http://www.ebay.co.uk/itm/Land-rover-defen...35ca863da9 For a 110 http://www.a2stainless.co.uk/Land-Rover-De...AJ5PM.aspx For those who like Welsh Mountains and narrow boats have a look at my videos and photos at.. http://www.youtube.com/user/conwy1 |
Thanks gilarion for the link
Glad to have helped.
As for the fastener links above. D'oh. |
