Home > Td5 > TD5 water pump - is it shot?
Super7
United Kingdom 1999 Defender 90 Td5 CSW Rutland Red
I've just crawled under the Landy to change the oil and noticed a coolant leak...
I think this is the steering pump bracket, is it time for a new water pump?
Thanks Sad
 '99 TD5 Defender 90
'52 Series 1 80"
'99 Caterham 7
Post #428309 3rd Jun 2015 12:23pm
Fatboy Slim
Wales
Yes looks like it
Post #428414 3rd Jun 2015 8:01pm
Super7
Thanks, that's my weekend sorted then Big Cry '99 TD5 Defender 90
'52 Series 1 80"
'99 Caterham 7
Post #428516 4th Jun 2015 9:02am
Fatboy Slim
Wales
Easy enough. Get the gaskets and 'O' ring for the centrifugal filter housing as it needs to come off.
Post #428630 4th Jun 2015 7:35pm
grumpy old git
I've seen it done another way, remove PS pump from housing, four bolts to remove the entire bracket assembly from the lump and then swap the pump on the bench. There is an O ring that'll need swapping but it allows you to torque the pump bolts up correctly. I'll post the O ring part number when I get on the PC.
Post #428708 5th Jun 2015 9:03am
grumpy old git
I've seen it done another way, remove PS pump from housing, four bolts to remove the entire bracket assembly from the lump and then swap the pump on the bench. There is an O ring that'll need swapping but it allows you to torque the pump bolts up correctly. I'll post the O ring part number when I get on the PC. There's a post on d2boys club that is useful.
Post #428709 5th Jun 2015 9:04am
Fatboy Slim
Wales
Each to their own but I find that way an absolute pain in the backside. You'll do it easily in an hour or so by removing the centrifugal filter.
Post #428855 5th Jun 2015 7:01pm
Super7
Thanks, all sorted, took the centrifugal filter housing off Thumbs Up '99 TD5 Defender 90
'52 Series 1 80"
'99 Caterham 7
Post #429149 7th Jun 2015 8:38am
Fatboy Slim
Wales
Thumbs Up
Post #429201 7th Jun 2015 12:27pm
