![]() | Home > For Sale & Wanted > FS> Land Rover Snorkel |
discocuzzy Member Since: 16 Jul 2008 Location: surrey Posts: 1200 ![]() ![]() |
Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015 ![]() ![]() ![]() |
Shhhhhhhh.... all I will say is that I have been home 2 weeks and I have been a VERY busy boy ![]() Glyn ![]() |
Bomber82 Member Since: 20 Oct 2009 Location: Alessandria - Italy Posts: 216 ![]() ![]() ![]() |
Sent you a PM Matteo
Defender 110 Td4 SE MY 09 |
110SEB Member Since: 29 Jan 2009 Location: Essex, England Posts: 1444 ![]() ![]() ![]() |
Would your RAI obstruct a roll cage by any chance?
My identical RAI is rusting in the same place too? Why on earth did they not use stainless or even plastic for that bit? |
Pray tell what bit is rusty, The Mantec's I have that look similar the the ones pictured in this thread dont have steel on them to rust, so are the tops different from the Mantec supplied ones
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5977 ![]() ![]() |
There is a metal grill under the "hat" on the top, as Andrew says, you can only see it if you are under the snork looking up the side of it.
On mine there is a little rust, I think it is a low grade stainless steel. Andy |
That first pic looks like the lower part of the track over Grizedale...
Sure is ![]() Glyn ![]() |
Paul_1978 Member Since: 08 Nov 2009 Location: South Yorkshire Posts: 384 ![]() ![]() ![]() |
Is there some good action near Grizdale?
Went walking there this year. |
merebrowpaul Member Since: 19 Dec 2009 Location: United Kingdom Posts: 162 ![]() ![]() ![]() |
yes this was Gizdale to forgot where the track are but id like to go again if anyone going up .
![]() Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() Last edited by merebrowpaul on 18th Oct 2010 12:52pm. Edited 1 time in total |
I do. That's a great lane as you go up from the visitor centre past the sculptures then down the other side. Just uphil from the pic they've put a big rock to stop the daft types from cutting the corner which for some reason lots of people had begun to do. Also certain areas of it have been flattened out this year by the council, more gravel added too. It was better last year but I can see why they've done it as the snow and subsequent water did a lot of damage. Paul, there isn't "lots", the main lane across is the one in glyns truck. it goes from very close to the visitor centre across the hill and down, and at the bottom you turn left on to the main road then go up through hawkshead onto the next one, the closest of which goes through a quarry and is a decent length. Last time we did that particular lane was in august after we did Walna Scar in the morning, just before it was closed (again) |
yeah we started at the visiter centre but was following the one in front so didnt take much notice of the way . BETTER TO REGRET THE THINGS YOU'VE DONE THAN REGRET THE THINGS YOU HAVE'NT
That is the one ![]() Glyn ![]() |
Paul, I know that area pretty well. Where are you based?
