Home > Technical > Jerking on Bumpy Roads
shoclon
2009 Defender 90 Puma 2.4 HT Zermatt Silver
My defender goes into limp mode. I have a bearmach diagnostic tool. Two faults have refused to clear. First is the “Glow plug relay circuit invalid” and the second comes up a little while after the engine is fully warmed up. It jerks on bumpy roads and gives a cylinder balance, injector leaking fault. How can I solve these problems? I have installed new parts, EGR, MAP, Glow plug Relay and a new injector on cylinder #1. Dropped the fuel tank and had it cleaned, serviced Etc. read the injector codes and learned. How can I get my defender working properly again?
Post #428333 3rd Jun 2015 1:20pm
shoclon
In fact, when i keep the clutch depressed, it does not jerk. Whilst idling, there is also a knocking noise from beneath if the clutch is not depressed
Post #428367 3rd Jun 2015 3:54pm
