Home > Puma (Tdci) > Wobbly rear wheel - bearing fail after only 26k?
Page 2 of 2 <12
Last time I met one with these symptoms the bearing was actually fine but the large central hub nut was loose! It was staked down, but was half a turn slack and nothing like torqued correctly. I never did find out who the moron who did it was.
Post #427933 2nd Jun 2015 12:27am
taazzukcb
United Kingdom 2004 Defender 110 Td5 DCPU Stornoway Grey
If I remember right, Puma's went back to the 'proper' way of doing bearings, not these silly spacers in a TD5 (though the logic was understandable to an extent).
I can bring enough to have a look on Weds? I can even bring a complete bearing pack if need be :p ... Got a couple spare packs in me shed!
Wont take 10 mins ( Whistle ) to strip the hub off, give it a good grease up and do it back up!
I cant imagine LR are very generous with greasing them up in the Factory. But even so, 26k is a bit surprising! I would guess, like blackwolf mentioned, the lock nut has come undone (through a badly staked tab).
Post #427961 2nd Jun 2015 9:00am
....and you buy the bacon!!
Post #427963 2nd Jun 2015 9:01am
Pumas have the late TD5 arrangement - a spacer between the bearings, and a single stake nut done up rather tight.
There is however no reason why you can't ditch the spacer and revert to the earlier two nut and tab washer arrangement.
Post #427966 2nd Jun 2015 9:26am
Jim_Bean
Well i managed to drive it here to the Plantworx stand. Its making horrible crunchy noises but I have little choice.
I have to get back to base (9miles) and then back here again in the morning. If you can bring a repair pack down I'd appreciate it!
Post #427978 2nd Jun 2015 10:12am
taazzukcb
Blackwolf, You are indeed correct. For some reason I thought Puma's went back to the locknut method. Just checked MicroCAT and thusly saw all the spacers.
Either way, the bearing races themselves should be the same size, so they'll do the job if its toast!
Just be ruddy careful later James!
Post #427991 2nd Jun 2015 11:13am
AndyRichards
Just noticed a comment on the tread saying John Richards of Hinstock near Market Drayton looks to be closing down, i am the senior partner in the company and we are very much open for business.
Post #629487 6th Jun 2017 3:24pm
agentmulder
Kuwait
If you're going to commit to a recovery anyway may as well open it up and have a look? Just the flange removal may tell you a lot... Solved the bowel problem, working on the consonants...
Post #629543 6th Jun 2017 9:14pm
The original post is two years old, so he's probably got home by now Laughing Darren
Post #629575 6th Jun 2017 11:03pm
agentmulder
Kuwait
Embarassed
Well, just in case he's still wondering what to do next ....
EDIT - just realised that was my thousandth post - smooth! Laughing Solved the bowel problem, working on the consonants...
Post #629577 6th Jun 2017 11:07pm
Page 2 of 2 <12
