|  | Home > Wheels & Tyres > Dynabeads |
| K9F Member Since: 12 Nov 2009 Location: Bournemouth Posts: 9610      | Mixed reviews but generally very good.
 http://www.defender2.net/forum/topic29747....cing+beads If the valve is at 12 o clock none of the beads would escape if deflating. I have the 4x4 larger ones just for convenience as it was a new set of tyres going on. Be wary as different providers recommend different weights and some people have not had success. I went to Dynabeads.co.uk and whilst perhaps more expensive than Devon 4x4 the charts differ for certain sizes by up to an ounce per tyre. If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! | ||
|  30th May 2015 3:24pm |
| need4speed Member Since: 23 Nov 2012 Location: Kilmarnock Posts: 749  | Thanks for the tip    Yes I feel that I will go with Dynabeads themselves. Probably safer to err on the side of too many rather than too few beads. I will be using 35" tyres on mine so hopefully the beads will be up to the job. Time will tell I guess. How have you found them to behave if you are on a rough road or hit a pothole? | ||
|  30th May 2015 4:31pm |
| K9F Member Since: 12 Nov 2009 Location: Bournemouth Posts: 9610      | Once fitted I had a slight vibration at 50mph only but the tyre fitters had inflated all the wheels to 36psi. Once I lowered the fronts and raised the rears the issue has vanished. Potholes I try to avoid and with my 305s it'll have to be a biggun to affect vehicle trajectory. I am glad to be rid of all the stick on weights I used to have as they look extremely shabby after time.
|  30th May 2015 4:47pm |
| Posting Rules
