![]() | Home > Technical > Rear Reverse/Fog Lights |
The only possible drawback I can envisage carrying out this modification on any other truck would be that if you wanted to ft a swing away wheel carrier later on, you'd be stumped. If you go through life with your head in the sand....all people will see is an ar5e!!
PCA42 Member Since: 15 Jun 2014 Location: Church Stretton Posts: 468 ![]() ![]() ![]() |
Both those points definitely valid
![]() And yes, the swing away carrier problem did cross my mind once I'd fitted them ![]() 2010 Discovery 4 GS TDV6 1972 Series III 88" 2.25P |
I recently went Wipac LED and was considering 'doubling up' as I thought it was a great idea but I didn't look at my 90. Needless to say I hastily cancelled the extra fog and reverse when realising my error. As for the bumperette I reworked mine grinding off the original brackets subsequently fitting different angled brackets to pick up on other securing bolt locations to the swing away.
![]() Click image to enlarge ![]() Treat every day as if it is your last....one day you will be right!! |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20916 ![]() ![]() |
Looks good Mal.
Litch Member Since: 10 Mar 2013 Location: Oxfordshire Posts: 767 ![]() ![]() |
Not necessarily, depends on the make of carrier. People often say that you can't have a full compliment of NAS lights and / or a swingaway carrier and / or bumperettes but my vehicle has them all. [URL=] ![]() Click image to enlarge[/URL] Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
What bumperettes are those? they look like mine but I never bought them the previous owner did so didn't know the make.
What carrier is that too Litch?
Your truck really does look cracking with those grey Sawtooths and ST Maxxs! ![]() 2010 Discovery 4 GS TDV6 1972 Series III 88" 2.25P |
