Home > Wheels & Tyres > BFGoodrich All Terrain 2nd hand buying
JJ440
Switzerland 2001 Defender 90 Td5 SW Oslo Blue
Hi, looking at a second hand set... hence the following questions
What's the min. tread depth on these tires (1.6mm?), apparently there should also be an indicator?
Also, from what age do I steer clear, older than 6 years?
Post #427084 29th May 2015 2:22pm
K9F
1.6mm is in UK. Minimum tread depth of 3mm in France. It varies! If you go through life with your head in the sand....all people will see is an ar5e!!
Post #427101 29th May 2015 4:11pm
o4dn
France 2009 Defender 90 Puma 2.4 SW Alaska White
In French here:
http://www.legifrance.gouv.fr/affichTexteA...e=20150529
1.6mm in France as well.
Post #427106 29th May 2015 4:32pm
K9F
Laughing
I just had two tyres swapped out on my company car unecessarily as their belief was 3mm. Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #427110 29th May 2015 4:40pm
Bows
Wales 2006 Defender 110 Td5 SW Alpine White
The tread wear indicators are usually set at 2mm, the Legal limit In the UK is 1.6mm at three quarters of the width of the tyre which must include the centre band. 2006 TD5110 station wagon
1995 300Tdi 90 truck cab
1989 90 hard top with 200 tdi
1983 110 hard top
1983 110 Hi cap
1954 107 pick up
Post #427119 29th May 2015 5:32pm
I find the thought of only having 3mm of tread quite terrifying. Mine come off before they get down to 8mm.
Post #427122 29th May 2015 5:40pm
camelman
agree with blackwolf, 3mm is almost bald!!
I've now got 30k miles on the BFG KM2's and still have 11mm tread all round.
If you're looking at 2nd hand tyres with only 2 or 3mm left they must have done some serious mileage...
Post #427125 29th May 2015 6:09pm
o4dn
I'm probably going to state the obvious here, but thread wear is not the only factor to consider when buying 2nd hand tyres.
I am about to replace my 5 tyres (that I bought a year ago) at once with brand new tyres because they're more than 10 years old, with small cracks and they cannot be properly balanced because they are not round, and yet they have fairly deep threads remaining...
Post #427145 29th May 2015 9:06pm
RobKeay
I've heard people claiming 100k on bf tyres. I did 36k on km2 and was at 12mm.
Post #427155 29th May 2015 9:34pm
camelman
I've also had 85k out of a set of KM1s and they still had 4-5mm left.
If theOP is looking at a set with 2-3mm that would suggest very high miles on em.
Post #427167 29th May 2015 10:33pm
The last set of BFG muds (original style) from my Disco2 came off after a genuine 100,000 miles and had 6mm remaining. The KM2s on my Defender have now done 68,000 miles and have approx 10mm remaining.
My impression is that KM2s are a softer compound than the originals and wear slightly quicker.
Post #427183 29th May 2015 11:58pm
JJ440
Looking at 10mm, they start life at 13mm right? Seems reasonable, except for the white lettering Mr. Green ...is it removable without excessive damage to skin or tire?
Post #427723 1st Jun 2015 10:19am
Lambley
United Kingdom 2006 Defender 90 Td5 HT Java Black
Me too, I don't think I'd ever let a set of tyres get down to anywhere near 3mm, especially if the wife's driving (!)
I tend to swap them at around 6/7 mm - which is normally around 50% worn, then you can normally get a few quid for them and put that towards a new set. I don't do many miles in my 90 so tyres will last ages anyway, so they'll only wear at around 1mm per year, so after 6 years they're ready for a change anyway.
Post #427735 1st Jun 2015 10:31am
