Home > Camping, Caravanning and Holidays > Awning lighting
Davidej
United Kingdom 1996 Defender 110 300 Tdi SW Alveston Red
Awning lighting
Am looking at options to provide 12v lighting under my awning and also possibly in the back of the 110. Have seen some flexible strip options which connect together by Ring and others. Would welcome others views on portable lighting options which are easy to hook up and robust
Post #426869 28th May 2015 2:04pm
HI, MUD do a good light, which I'm actually going to fit to my 110, they can double as a reverse light too.
here's the link..
http://www.mudstuff.co.uk/products/electri...e-s17.html
Post #426875 28th May 2015 2:42pm
TheWarden
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Aintree Green
If you go to the bottom of the page, that is my Defender with two fitted.... 2013 Aintree Green 110 Station Wagon SX
Post #426882 28th May 2015 3:39pm
Trek Overland
Site Sponsor
United Kingdom 2011 Defender 110 Puma 2.4 DCPU Fuji White
You can buy LED Strips Kits with everything you need for it to work from us. The led strip is actually adhesive so you could stick it to the mounting beam or anywhere you like in fact. £70inc for a 2m led strip.
We could also recommend the nebula light as shown here. They are fantastic lights that are IP67 rated, switched and durable.
For people on a larger budget (and those who like gadgets) we also offer the very high quality Biolite NanoGrid which can spread light over a vast area with a linkage of lights. It can also charge USB items such as phones, ipads, sat navs etc
Here is the NanoGrid
And they can be bought from here
Thumbs Up
www.trekoverland.com | 01751 430 693 | info@trekoverland.com
Expedition Equipment for you and your 4x4!
www.mobilestoragesystems.net | 01751 430 318 | info@mobilestoragesystems.net
For all your secure storage needs!
Post #426886 28th May 2015 4:00pm
Davidej
thanks guys. will take a look at these options over the weekend.
Post #426893 28th May 2015 4:52pm
Trek Overland
Site Sponsor
Youre welcome David.
Just found a picture of the led strip we supply. Looks really quite cool where its mounted on this vehicle.
Thumbs Up
Post #426894 28th May 2015 5:17pm
Davidej
Ooh like that. Is it just adhesive or is it fixed another way? Assume it will work off cigar lighter.
Post #426896 28th May 2015 5:21pm
wyvern
United Kingdom 2012 Defender 110 Puma 2.2 XS CSW Firenze Red
Thumbs Up
do you have a link to the led strip ....?
Very Happy Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html
Elgar -TDCI(Puma) 110XS Dormobile - now sold
Devon & Cornwall 4x4 Response - DC126
Post #426960 28th May 2015 9:25pm
AndrewS
here's the link..
I have got a set of these fitted and to be honest the are so bright the hurt your eyes, they are great if you want scene lighting and are working around the vehicle but IMO they are too bright when facing the light under the awing.
As a result I got a pair of these http://www.mudstuff.co.uk/products/electri...e-s18.html they are not as bright but still produce more than enough 'awning' lighting Thumbs Up 130's have feeling's as well you know Smile
Post #426994 29th May 2015 6:09am
I fitted a mud stuff scene light for reversing but also for camping. Like AndrewS it's a bit too bright to sit around, so I added a led remote controller, so,I can switch on/off remotely and has a brightness 100-50-25% option .. Works a treat, I can switch on/off from anywhere about 15metres and makes wiring the light 4 soldered connections from the purple/black wires in the rear
Post #427008 29th May 2015 8:06am
AndrewS
I like the 100 50 25 option do you have a link to the place you got the remote from, power to my lights are from the aux batteries. 130's have feeling's as well you know Smile
Post #427028 29th May 2015 9:30am
Trek Overland
Site Sponsor
Its just a high quality adhesive stick. Its powered by 12v and we supply it wired in and with a switch so they obviously can be turned on and off when you like.
Post #427056 29th May 2015 11:21am
Trek Overland
Site Sponsor
Thumbs Up
Very Happy
Im afraid its not currently on our website. However if you give Clare an email at info@trekoverland.com she will be able to give you the full spec of the product and answer any questions you may have.
Post #427057 29th May 2015 11:24am
Alien
Australia
I have one of the stick on strips and attached a merit plug to it.
I mounted it to the main awning bracket(under the rope rail) and the lead goes under the tie up straps inside the cover for traveling.
I've fitted a merit outlet that's mounted through the rear panel between the number plate and the number plate light.
Under instruction from the cook we also have a rear mounted LED light from MUD.
The switch is mounted under the number plate light extension housing.
http://www.mudstuff.co.uk/products/electri...-lamp.html
Both of these lights work off our second battery Cheers,
Kyle.
Post #427139 29th May 2015 8:28pm
Pam W
England 1998 Defender 90 Td5 SW Auto Oslo Blue
We have the Ring Tent lights. http://m.gooutdoors.co.uk/ring-27-led-tent-light-kit-p195324
We have 1 inside the roof tent, and 2 stuck on the underside, which provide light 'downstairs', either with or without the annexed zipped on. You can connect several together so you only need 1 connection to your power supply, but still have separate switches. Our blog - http://landytravels.com/
Yorkshire Off Road Club - http://www.yorkshireoffroadclub.net
Post #427204 30th May 2015 10:20am
