![]() | Home > Td5 > What is this switch? |
| kweese Member Since: 28 Apr 2015 Location: Van Posts: 62
Click image to enlarge When I got my 1999 csw, there was this switch beside the front passenger seat. Secured by the compartment box. I took out the seat and followed the wire. It runs into the battery compartment. Does anyone have an idea what this is? Click image to enlarge Click image to enlarge Last edited by kweese on 25th May 2015 11:54am. Edited 1 time in total |
| Force64 Member Since: 02 Jan 2014 Location: Gatwick Posts: 196
Photo please?
Andy Defender Td5 XS90 |
| shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3347
Useless as far as I can see as whatever it was plugged into is now missing!
Looks like it may possibly have been some sort of control for a simple Webasto Setup but if it was me I would follow the wire back and then remove it as it seems to be doing nothing. It doesn't look like a factory fitted item. Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197 Self confessed mileage hunter |
| K9F Member Since: 12 Nov 2009 Location: Bournemouth Posts: 9610
It looks like a Telemechanique 'style' switch. If so the contacts NO/NC are readliy available and the rotary switch is also interchangable with numerous different types illuminated/latched/momentary etc. Is it fused and if so what is the rating? It may give an idea what it may have been used for? If it is not protected remove it as it is of no use as suggested.
| CDN38 Member Since: 14 Nov 2014 Location: Courtenay, BC Posts: 729
Definitely not stock. If it's not wired into anything, just remove it.
I had the same with my TD5 when I got it, there were 2 sets of wires and relays to brackets on the bumper for lights that weren't there anymore. It's just extra clutter that isn't needed. All these trucks coming over here are 15+ years old and may have had several previous owners, there is usually some remnants of them, often in the electrical. Last edited by CDN38 on 27th May 2015 8:34pm. Edited 1 time in total |
| GSLRO Member Since: 13 May 2012 Location: Tyne and Wear Posts: 499
| Buz Member Since: 24 Jan 2014 Location: Forest of Dean Posts: 238
Flux Capacitor switch...just don't operate it if/when you hit 88MPH
