![]() | Home > Maintenance & Modifications > MY15 110 Removing door cards for sound proofing |
| custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21022
Trim removal tools, one of those things 59/50 between force and care.
Protect the paint just in case in places if you need to and that should be it. Don't forget to remove the door handle, the handle opening recess piece and the locking pin slider shroud section first. Once off, behind there you will find sone thin foamy stuff which is pathetic sound deadening insulation stuff. All the same carefully tease the sealant off all the way around taking care not to rip,it do you can put it back on. The adhesive stuff is something that should* stick back on as it seems to stay sticky. Once all of that is off your back to the bare door inners. If your actually sound proofing them you might not need the foam bit again but that's up to you. Don't forget some heat and a roller if you don't have enough already. |
| Defender2014 Member Since: 25 Aug 2014 Location: Buckinghamshire Posts: 65
Hi,
I found when I did mine that if you stretch the sealant it will slice easily with a sharp Stanley blade, also leaves a bit stuck to the door thus giving you a location guide when sticking the foam back on... Defender Puma 110XS SW Kawasaki ZX9R El Suzuki RGV250M Honda CB250N Super Dream |
| Natlas Member Since: 20 Mar 2013 Location: West Sussex Posts: 463
I found that LR had already put some sound dampening on at th factory so put it all back together and left it alone.
88" Series One Old Norton Modern Honda and Harley |
| Rudski Member Since: 13 Jul 2014 Location: Lake District Posts: 141 |
Same as. Defender2014 sharp Stanley did the job
| GypsySamuraiAnt Member Since: 31 Mar 2015 Location: Brisbane Posts: 131
Thanks everyone greatly appreciated!
I might frame the factory sound proofing as memorabilia |
