Home > Puma (Tdci) > Looks like im coming back
mse
Well after 5 years, it looks like we are coming back to defenders (although this time keeping the others!).
Its been a while, we have a build slot and will be getting a 110 - although we have some time to change spec etc
I think we will be getting an XS Utility Wagon - whats changed in 5 years spec wise, what to look out for? Mike
Post #425890 24th May 2015 12:00pm
Spookytooth
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Aintree Green
5 years - Nothing! Not quite true, the spec keeps changing between carpet and rubber mats on the XS model
Post #425923 24th May 2015 4:00pm
ericvv
5 years.... Well, you get a leash on the fuel cap in order not to loose it, and you get some holes in the rear door handle (part of LR weight saving program and Eco footprint improvement for the Defender). Oh, and you get a DPF. Rolling Eyes You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #425939 24th May 2015 5:34pm
alby
United Kingdom 2015 Defender 90 Puma 2.2 SW Santorini Black
Don't forget, traction control and ABS as standard from MY2014 onwards and stability control as standard from MY2015 onwards.
Also got a supposedly slightly upgraded alarm for 2014 with a different type of remote fob. battery Backup alarm sounder standard now too (from 2012?)
Post #425956 24th May 2015 6:56pm
bob neville
But the good news is .... you still get dodgy clutches, terminal output shaft failure, water ingress etc Rolling with laughter
Welcome back Thumbs Up
2013 Defender 90 CSW - sold
Post #425987 24th May 2015 10:02pm
mse
Thanks everyone...I did notice that after hundreds of years (ok exaggeration) the weight saving/cost saving on the rear door handle.
Having been one of the first to post about clutches - I forgot I had 1 or 2 back in the day, its not the best to hear they still break - water ingress wasn't that bad on the 90, I certainly wouldn't have sunroofs!
Looks like a September build for ours, 110 utility wagon, probably XS spec - detail to be planned
Have they fixed the or improved the bonnet theft stuff - just as sold the last 90 they were going faster than they could be made, I had my own security - but it would be good if there was a fix.
I also noticed it seems difficult to get a contrast roof, despite seeing 2 with them in 110 form - am I missing something or is the website wrong? Mike
Post #426455 26th May 2015 6:34pm
bob neville
Hi Mike
Clutches still go, same problems as the 2.4. Mine has just been replaced at 17K.
Bonnet's are exactly the same as the 2.4, still removable but a number of companies offer security hinges now.
Contrast roof was an option when I got mine in 2013, and were still an option in 2014. Maybe they have now removed it ?
Not sure if this is a common problem or not but mine is now throwing the MIL light at every opportunity with a P0130 code and various others. Nobody seems to know what is going on but it only happened after the clutch was done.
Dealer has seen one before and it was a damaged or corroded harness. LR themselves are supposed to be on the case this week - time will tell Whistle
One thing that takes a bit of getting used to on the 2.2 is the rev hang on gear changes, it is supposed to make the change smoother. Some like it some don't.
Post #426461 26th May 2015 7:02pm
mse
Thanks
On the roof we cant fully tell, there does seem to be one option of the silver design pack, but eventhing else seems to imply the roof isn't available on 110 hard tops we will see.
I cant believe (well I can) that the bonnet security hasn't improved, I did naturally assume the clutch might be better on the 2.2 v the 2.4, but clearly not.
Funnily this car will replace my wifes, so I better get her to drive it see if she likes the rev thing Thumbs Up Mike
Post #426490 26th May 2015 8:20pm
AndrewS
Welcome back Thumbs Up and welcome to DSC Shocked 130's have feeling's as well you know Smile
Post #426513 26th May 2015 9:08pm
mse
thanks and the lack of space to put the spot light switch Big Cry Mike
Post #426538 26th May 2015 10:01pm
