Home > Maintenance & Modifications > here the Recaros has landed
dgardel
Italy
I need the MUD STAFF raisers, I have to raise them a little especially on the back, I find the seat a bit' too sunken back. Any suggestions?
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #409994 22nd Mar 2015 9:03pm
pob1968
That really is a lovely Defender 110 Hardtop
Post #409997 22nd Mar 2015 9:06pm
K9F
Nice seats Daniele....Pasta and lots of it! Eat more get a fatter ar5e and you'll find the seating position perfect. Thumbs Up Laughing If you go through life with your head in the sand....all people will see is an ar5e!!
Post #410000 22nd Mar 2015 9:11pm
Green Machine
I thought they were for a friend DG? Whistle They look awesome. I'm very keen to get some for mine. Where did you get yours from? 2005 Td5 | 90 Station Wagon | Tonga Green
Post #410001 22nd Mar 2015 9:12pm
dgardel
Italy
IID Pro MV License
Post #410004 22nd Mar 2015 9:14pm
ericvv
Re: here the Recaros has landed
Daniele, as you come from Scheelman seats which are giving a real high up seating position, you went straight to the extreme opposite situation as the Recaros provide a very low seating position. Why don't you give it a bit of time to get used to this "as is", and then see if you really need to be higher up or not?
I presume that you will agree that these Recaros in combo with your smaller than standard steering wheel give us the best possible overall room in the by definition not so big Defender seating position.
By the way, nice road map between those seats. Thumbs Up
Eric
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #410086 23rd Mar 2015 5:29am
dgardel
Italy
Thank you Eric
yes, nice map... Mr. Green
I think that the mud raiser will be THE solution because I need a little more legs room as I'm a 1,83m but with long legs.
Imho, with the Mud raiser sill be the perfect seats configuration.
And now I can still say that the Sheelmann are also great seats..... Whistle
however, I have no reason to look back... Thumbs Up Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #410096 23rd Mar 2015 8:40am
dgardel
Italy
ex-tec risers (stainless steel) installed!!
i'm so happy!!!!!!!
IID Pro MV License
Post #411588 28th Mar 2015 12:58am
K9F
Recaros have landed here too. Thumbs Up
Have been keeping my eye out for some considerable time for the right set with heaters and removable bases. Got a set of covers thrown in too. Very, very comfortable. I was also able to retain my Exmoor Trim Seat Risers with the fit that suited me well.
Original risers...old seat.
Pretty much the same pictures as Daniele really.
Covers.
Post #426372 26th May 2015 12:15pm
dgardel
Italy
Thumbs Up Thumbs Up Thumbs Up Thumbs Up Thumbs Up Thumbs Up Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #426374 26th May 2015 12:21pm
Glad you have seen the light Thumbs Up
Post #426381 26th May 2015 12:52pm
dgardel
Italy
Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #426385 26th May 2015 1:09pm
K9F
^^ Nice one Daniele. Laughing Laughing
Whilst the seats are 'egonomically shaped' and fits the upper torso and my f4t ar5e perfectly it appears the covers are not quite so. After a little fettling and wrestling I have decided just to fit the cover to the passenger seat for the sake of my daughter(s) and partner. The driver's side can remain natural until I either become incontinent or start leaving enough food laying around to feed a third World country after snacking as everyone else appears to do. Why all the food and drink doesn't seem to reach their intended destination beats me? My driving in mitigation may have something to do with it perhaps?
Rolling with laughter If you go through life with your head in the sand....all people will see is an ar5e!!
Post #426388 26th May 2015 1:34pm
dgardel
Italy
Rolling with laughter Bow down
I bought this one and the next weekend I'll put on it
http://www.inka-corp.com/Defender-Recaro-T...rchSize=12 Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #426392 26th May 2015 2:02pm
K9F
Very similar to the ones I have with the four velcro fasteners where the holes are. Whilst they are functional it is a shame really to cover the beauty of the seats themseves. As stated the driver's I have left natural and will stash the cover in the rear should I ever need to use it. As the Defender is covered when not in use I don't need to worry about UV degredation. Just washed the covers and they came up a treat.
Due to the width of my old seat bases, heavy individuals and the seat risers I fitted some extrusion to the edge of them to prevent the seat bases from chafing on the edge. With the Recaros I may well remove it as the bases are miles away.
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #426393 26th May 2015 2:13pm
