Home > Series Land Rovers > Started having bad thoughts about buying a S2
Page 8 of 24 <123 ... 789 ... 222324>
Last time I took my 86 for an MOT the inspector made the same mistake!
Post #425670 22nd May 2015 10:59pm
TJ101
So,, you MOT your blackwolf Question Just wondering whether to bother or not ?? California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #425671 22nd May 2015 11:04pm
Not any more, that was when you still had to!
I see no point whatsoever paying good money to get someone who knows virtually nothing about a vehicle of that era to tell me the wheelnuts are back-to-front, or asking me how to start the engine, or where is the switch for the wipers! Where's the filler cap was another classic.
Post #425672 22nd May 2015 11:09pm
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
^^^^ Right answer! Rolling with laughter 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #425686 23rd May 2015 7:28am
milesr3
2016 Defender 90 Puma 2.2 XS CSW Keswick Green
Lots of small bits going back on; nearside bulkhead to chassis bracket, bulkhead tie bar, throttle linkage, choke assembly and starter button:
The choke panel scrubbed up well and is a decent colour match with the new paint:
Jubilee clips binned and replaced with the correct double wire hose clips:
And I've put a few galvanised bits back on as they came off:
Post #426178 25th May 2015 6:10pm
ian series 1
Looking good,
I should be at rolling chassis stage in a week.
An exciting time of any restoration Very Happy
Looking forward to seeing it with its body on, keep up the good work! Thumbs Up 80" 80" 86" 88" 90"
Post #426185 25th May 2015 6:37pm
Ellisboy
1998 Defender 90 300 Tdi CSW Epsom Green
Looking splendid Thumbs Up
Post #426233 25th May 2015 9:13pm
Loving this build.
Interesting that you put the galv parts on as you took them off.
I'm leaving my galv cappings as is, it does give it a more patina'd look, as new galv does look a little bit 'blingy'.
I like your hose clips Cool
Post #426266 25th May 2015 11:48pm
milesr3
I got the radiator panel blasted yesterday, primed right away and the first coat of enamel on today:
Post #427289 30th May 2015 7:44pm
milesr3
Second coat of Deep Bronze Green on and the radiator, grille and lights back on:
New rubber seals and the vent flap hinges back on with their original paint and rusty screws:
And the levers back on:
The last bit of the bulkhead and door check strap mounts painted and re-attached:
Post #427831 1st Jun 2015 6:25pm
Venomator
What a cracking job you are making of this build Miles... Bow down
It is a joy to watch it progress, so thanks bunches for sharing your experience with us less talented/fortunate souls... Mr. Green
 Rog... Mr. Green
The GREEN One...
MY2016 Urban Truck Build Thread - http://www.defender2.net/forum/topic40548....al[/color]
Post #427834 1st Jun 2015 6:36pm
Greggster
United Kingdom 2007 Defender 110 Puma 2.4 HT Alpine White
Superb, just superb! Love this build, top notch Thumbs Up
Whatever you do just DO NOT press the big red button Very Happy
Post #427842 1st Jun 2015 6:54pm
milesr3
The last place that oil was obviously escaping from (I'm sure there will be others):
And the innards of the transfer box seem in good order.
Post #429403 8th Jun 2015 8:34am
bluebottle
I'm absolutely loving your work - and your photos!
What a thing of beauty, keep up the excellent work! Bow down
Post #429421 8th Jun 2015 9:35am
milesr3
Thanks fellas!
I got all the oils in over the weekend and will hopefully get the correct wiring harness from Autosparks this week, so it's getting close to being started again. Once the brakes are bled and the props back on, I dare say it will go for a sort shakedown up the road.
With the wiring done, I can then start to re-attach the bodywork and it will suddenly start to look finished.
Had another to paint or not to paint dilemma and in the end decided to paint the radiator cowling as it was towards the rusty end of the patina scale, but not the steering column bracket:
Post #429430 8th Jun 2015 10:15am
