Home > Technical > Rivet sizes
mk1collector
Rivet sizes
Hi all, does anyone know the size of the rivets that hold the rear mud flaps on? I've recently lowered my 110 and with living in a hilly area I now ground the mud flaps regularly so want to raise them around 2 inches. I'm going to replace the rivets with stainless bolts but am unsure of the size I need, I'm guessing roughly m4/25 mm should be in the ballpark but wondered if anyone knew a definate size.
Ray Thumbs Up Ray
My build thread
Post #424379 18th May 2015 9:04am
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
Ray,
I've got one up on the ramp as we speak,
I would say they are 6mm diameter by about 15mm long? They also have a washer on the rivet which is about 21mm
Can't give you exact dimensions as it would mean taking the flaps off! 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #424388 18th May 2015 9:31am
munch90
m6 and screwfix do some dome headed hex drive just right for job Thumbs Up
Post #424391 18th May 2015 9:41am
mk1collector
Excellent, I'll get some ordered and try and get them done this weekend Thumbs Up
Cheers chaps Cool Ray
My build thread
Post #424392 18th May 2015 9:44am
munch90
forgot to add screwfix ones are stainless m6x16mm or do 20mm as well
Socket Button Screws A2 Stainless Steel M6 x 16mm Pack of 50
Post #424399 18th May 2015 10:45am
kipperthedog
I get all my stainless fittings from an ebay seller called ABoltFromTheBlue. Reasonable prices and bolts, washers and nut are available in quantities of 5 upwards.
Post #424673 19th May 2015 6:24am
