Home > Technical > door hinge problem.
Likeomg
door hinge problem.
Well, the bolt heads had started to go so i decided to replace them all, bought the stainless bolt kit years ago lost it, found it never got around to it.
started on the pax side first, on the bottom hinge, bottom bolt it was chipped and i always wondered why... i found out the bolt head silicone'd in, pried it out trying to do the least damage to paint i could and found out it was just stuck in, not screwed into anything... will have words with land rover in the morning.
(had the bulkhead completely replaced by them under warranty)
so i thought ill sort that myself, the little metal clip was clearly missing the bolt, i used a stainless one fitted it into the clip tried to tighten it up and nothing, the bolt is just spinning, i looked at the top clip and the nut is actually a square one Censored
now i can't get the bolt undone and the hinge is just hanging...
any ideas how to get it out?
Post #424308 17th May 2015 10:14pm
grafty99
Bend a spanner? Get a cheap one to do it with. Bit of heat and a vice Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #424313 17th May 2015 10:31pm
K9F
It will knacker your hinge. Take a grinder or dremmel and by cutting through at an angle take the head of the bolt off. Remove the hinge and you should be able to cut the bolt release the square nut and extract it rearwards.
Alternatively if there is any play in the bolt you may be able to cut the bolt behind the hinge with a little force but there is a high risk of heat/paintwork damage.
The nuts are square if as above suggested you can find something small enough to purchase on the nut at a 90 degree angle that may be the best least damaging but most labour intensive option. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #424316 17th May 2015 10:36pm
Likeomg
its too narrow for a spanner... already tried it with some 90 degree things i have..
Post #424321 17th May 2015 10:49pm
grafty99
Can you pull the hinge hard enough away from the bulkhead to stop it spinning whilst drilling out the head? 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #424325 17th May 2015 11:07pm
grafty99
It being the bolt 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #424327 17th May 2015 11:07pm
Likeomg
that was my last effort solution up to now, but being stainless it might be a pig to drill.
tried pulling it away while i undo the bolt but no luck.
Post #424328 17th May 2015 11:12pm
grafty99
I think stainless is slightly softer so should be easier if anything to drill Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #424334 17th May 2015 11:40pm
nitram17
Two suggestions: 1 use small kitchen Gas burner to heat the nut (just enough to melt the silicon)
2 If there is a gap then glue the nut into the hinge............wait and turn the whole hinge
with the nut fixed in place!
Post #424335 17th May 2015 11:44pm
Likeomg
Don't like the idea of heat... Could try to epoxy but I'm as likely to get it on the screw threads
Hmm
Post #424337 18th May 2015 12:30am
dailysleaze
I've had to cut the bolt with hacksaw blade slid between the body and hinge. Took AGES.
Post #424339 18th May 2015 12:34am
scotia
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Corris Grey
Remove metal from both sides of the 90 deg spanner by grinding until it will fit through the access hole.
Post #424348 18th May 2015 8:13am
LRmud
Scotland 1989 Defender 90 300 Tdi HT Baltic Blue
Drill the head off the bolt. Start with a small drill first, then go bigger. Easy.
Other option - take it to Land Rover and get them to fix it! --------------------------------------------------------------------------------------------------
1989 Defender 90
Toyota Aygo & Honda FR-V
Post #424351 18th May 2015 8:36am
K9F
Had an afterthought how about a set of these to try and hold the nut? One of the jaws may fit down the aperture.
http://www.amazon.co.uk/locking-plier-125m...B00CIUVL0S If you go through life with your head in the sand....all people will see is an ar5e!!
Post #424361 18th May 2015 9:16am
Likeomg
I have a set of them k9, will try tonight
I've spoke to Land Rover dealers and the soonest I can book it in is the 4th June for an assessment
Post #424419 18th May 2015 1:11pm
