Home > Technical > TD5 engine and gearbox swap out
Mac87
Hi all
Now that my gearbox sounds to be on its way out, and along with the hard cold starting engine, I am keen on replacing both. While I'm at it, I have a Disco box with the diff lock internals which I'd like to fit.
So my question is - will I be able to slide all three out of the front end, or will it require splitting?
Also any handy tips regarding removal gratefully received!
Post #424250 17th May 2015 7:31pm
T1G UP
if you lift the front of the car up you can swing the lot out but i'd drop the transfer box out first.
Post #424268 17th May 2015 8:19pm
Mac87
Righto, thanks for that, I have a Loadall at hand so could be done but was just thinking of the most straightforward way, seeing as I'll be on my own for most of it. Will give it a go dropping the t box out first, cheers!
Post #425866 24th May 2015 10:00am
