![]() | Home > Technical > Axle diff vent hoses? |
YOLO110 Member Since: 14 Feb 2015 Location: Perth Oz and Stansted UK Posts: 1648 ![]() ![]() |
Hi Guys,
I noticed when I collected my Puma, that both the from and rear axle housings have what looks like a vent nipple fitted on the top of the casing, with a long run of 5-6mm black hose fitted to it. The hose runs back and up into the engine bay. Is this a breather hose? I am confused as I have looked under quite a few other Defenders and not many have this fitted? Was this an 'option' of some kind? I did not order it! Sorry no pics... I am away from my car atm! Cheers, Pete. YOLO... You Only Live Once... |
On my current Puma rear axle:
![]() Click image to enlarge Don't think I've had a single Land Rover over the last 30 years plus that didn't have them fitted - although previous versions have bee better engineered than these. |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17912 ![]() ![]() ![]() |
In the early days (leaf spring era) the breather vented straight to atmosphere via brass doobrey on the tube. For the last two or three decades breathers vent via a tube to a high point.
martinfiattech Member Since: 13 Nov 2013 Location: leicester Posts: 422 ![]() ![]() |
You might want to inspect the front axle breather hose, I found mine rubbed thru on the n/s/f front axle, suspension arm.
As luck would have it. The DAF truck dealer I work at have 5-6 mm air suspension pipes. these are a direct replacement. A couple of push / quick fit connectors, and the front axle is water proof again. (well as best it can be). Excuse the spelling I`am better with spanners and wires. |
Weird...!
I have looked under quite a few new Puma's and not all of them have this fitted... ![]() |
AndyTunn Member Since: 10 Jan 2015 Location: Auckland Posts: 313 ![]() ![]() ![]() |
Mine had the breather tubes from the front diff and transfer case running up into the engine bay, but the rear axle breather was just strapped up under the chassis. I took the plunge and routed all three to a dedicated "Nugget" manifold high up under the bonnet.
http://www.defender2.net/forum/topic34028.html |
