Home > Technical > Tdi engine fueled by a TD5 tank?
chrispy
Wales 1987 Defender 90 300 Tdi CSW Keswick Green
Ok, to cut a long boring story short I have a 300Tdi I'm restoring for my wife that has a TD5 rear bed. Rather than cut a hole in the side to fuel (which will never look as good) I plan on installing a TD5 tank with new brackets on the TDi chassis and extending the fuel pipe. How can I get the pump to fuel the engine as I believe the Tdi pump works differently to the TD5 one? Any advice would be gratefully appreciated.
Thank you.
Post #423886 15th May 2015 9:16pm
davew
England 1990 Defender 90 V8 Petrol PU Auto Rioja Red
The TD5 setup is completely different and not compatible with a 300TDi.
Having said that though, there IS a very simple solution - the 300TDi pickup from a plastic tank Discovery will fit a TD5 tank. You can then run a standard 300TDi Discovery setup. http://www.yorkshireoffroadclub.net/
Post #423921 15th May 2015 10:18pm
chrispy
Thanks very much Dave, it'll save a lot of cuting and welding on the side now to have a horribly shaped fuel hole lol Thumbs Up
Post #423931 15th May 2015 10:50pm
Lotus_esprit_s1
I have a ROW 300tdi 90 with this setup as standard.
The correct ROW fuel pickup / sender unit for a 300tdi 90 with rear plastic fuel tank is available for about £70 new from main dealers still. The disco one works but fuel gauge isn't accurate
Don't forget the exhaust pipe will need to be changed if you fit the rear td5 tank. The correct 300tdi ROW rear pipe is discontinued by Land Rover and no-one makes a correct pattern pipe. People will say that the late 300tdi rear pipe with no silencer will fit but it won't. Bearmach sell a pipe made by Bosal with the correct ROW part number but it is wrong - it is just a TD5 rear pipe.
You need to buy a standard late 300tdi 1997 onwards mid pipe with silencer and a standard TD5 rear silencer, you will need to make an extension piece to extend the mid section by 135mm with a 3 bolt flange to mate up with the td5 rear pipe - photos below.
Post #425443 21st May 2015 10:53pm
chrispy
Thank you my friend, most informative. I'll print this out along with the pictures and take it to the guy who's doing the work etc, it's bound to save him a hell of a lot of potching about (and me no end of money) in the long run. Thank you once again Thumbs Up
Post #425449 21st May 2015 11:08pm
Lotus_esprit_s1
I spent countless hours on the phone trying to order the correct pipe, ended up with three wrong ones, before realising that the RoW 90 is such a rare beast that I was on my own and knocked up that adaptor in 20mins! The mid section silencer needs the late rear mounting bracket which bolts directly to a frame crossmember by two m6 bolts, I think YRM do them if yours is an earlier 300tdi.
Post #425455 21st May 2015 11:18pm
munch90
for fuel tank
isn't the td5 and tdci the same tank , but the td5 has a electric fuel pump , tdci 2.4 doesn't , so could you use the tdci fuel pick up in the td5 tank doing away with electric pump or use a tdci 2.4 fuel tank complete ?
sorry don't know 100%
Post #425473 22nd May 2015 8:13am
chrispy
Bloody hell there is so much to learn isn't there. Thank you both Lotus_esprit and Munch for your expert opinions, i'll take them back to my mechanic chappie and see what he says. Thank you both very much Thumbs Up
Post #425817 23rd May 2015 11:12pm
shaggydog
Off topic but .....This thread is a perfect example of why I love this forum so much Bow down
Share the knowledge! It enriches us all! Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Self confessed mileage hunter Very Happy
Post #425818 23rd May 2015 11:16pm
chrispy
Exactly Thumbs Up
Post #425819 23rd May 2015 11:18pm
K9F
Lotus_esprit_s1 wrote:
The correct ROW fuel pickup / sender unit for a 300tdi 90 with rear plastic fuel tank is available for about £70 new from main dealers still. The disco one works but fuel gauge isn't accurate ]
Blimey that's cheap when I had my 300TDI Disco it was a lot more money. I initially thought I'd save a bob or two and bought 'reconditioned' and had to exchange it as it was making a hell of a racket, the second too the sender didn't work and I ended up buying new. If memory serves me correctly the combined unit was well over £200 at that time. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #425846 24th May 2015 8:20am
munch90
thinking about it you may find the fuel level sender in the tdci tank might not work with a 300 tdi gauge
Post #425864 24th May 2015 9:40am
gilarion
Had a similar problem when I rebuilt my project and changed the rear tub to a TD5 one, so I installed this pipe to run from the TD5 back filler to the under seat tank. I got a stainless steel exhaust manufacturer to make up the pipe for me think at the time it cost somewhere in the region of £50.00 and works a treat.
You will also need a length of rubber tubing to extend the breather pipe all the original rubber hoses from filler neck and fuel tank are still used, though I bought new OEM ones.
It really is a simple job to fit once you have the stainless pipe and a few hose clips.
 For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #425896 24th May 2015 1:06pm
Dave
United Kingdom 2006 Defender 90 Td5 XS CSW Zambezi Silver
Thumbs Up cool, extra capacity too - ish Laughing Captain Nick Medhurst would ask:
"What is the first rule when overlanding?"
I would Reply:
"Duratrac"
Post #425897 24th May 2015 1:09pm
gilarion
Yes Thumbs Up
When I fill up to capacity I reckon I get an extra six or seven litres (great when you have a Tesco voucher for 10p or 20p a litre off Laughing).
The great thing about this mod is you leave everything as it is exhaust, fuel tank, electrics, pump etc.
And it saves you a fortune by not having to replace anything. And if the garage who is doing your work can bend pipe then you do not even need to find an exhaust manufacturer to do the pipe. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #425898 24th May 2015 1:25pm
