Home > Maintenance & Modifications > Just a little washer jet tip that might come in handy.
gilarion
I have been trying to adjust my windscreen washer jets today and had difficulty. I was using sewing needles in the nozzle hole that would bend before they moved the nozzles, I then tried little veneer pin nails and they were to fiddly. I then had a brainwave and used the tool you get supplied with pressure washers to unblock the high pressure jet nozzle; obviously this tool is high tensile steel and fitted the washer jet perfectly and was an ease to adjust them the steel pin did not bend or break. I now have washer jets that spray the water where it cleans the windscreen perfectly. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #423816 15th May 2015 3:13pm
Venomator
Great tip... Bow down
Only thing is, I don't recall getting any such implement with my pressure washer... Rolling with laughter
 Rog... Mr. Green
The GREEN One...
MY2016 Urban Truck Build Thread - http://www.defender2.net/forum/topic40548....al[/color]
Post #423847 15th May 2015 6:43pm
Clive
United Kingdom 2004 Defender 90 Td5 X-Tech LE Zambezi Silver
Me neither, gilarion must have a very special pressure washer Razz
Post #423873 15th May 2015 8:46pm
gilarion
I am sorry your set up does not have this tool, so my tip is useless to you,
If you buy a more a recent model of a pressure washer it may be.
I have three pressure washers one is a three year old Karcher, one is from Machine Mart that is just over two years old and one I bought from Aldi less than a month ago and all of them have this tool attached to the body of the washer, with the exception of the Machine Mart one which had this tool attached to the packaging. If you are unfortunate to have a really old pressure washer then maybe because of its age then no service tools were provided, then my tip is useless to you. However, if you buy a more recent model of an up to date pressure washer then this tip is very beneficial. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #423942 15th May 2015 11:43pm
Venomator
Bit weird, bought my Karcher less than a year ago... Shocked
 Rog... Mr. Green
The GREEN One...
Post #423965 16th May 2015 7:50am
