Home > Puma (Tdci) > Positive Crankcase Ventilation Hose
I noticed that there were traces of oil on the outer pleats of the air filter in a perfect circle where the hose joins the box. So I'm thinking that the vent hose that joins the main air intake into the turbo is actually venting back the wrong way and getting all the way back to the air box.
It's not much but taking the hoses off there were traces of oil throughout. Worth a clean and as I think the air filter is evenly sided maybe turning the filter through 180 degrees after a year?
Post #423408 14th May 2015 8:36am
munch90
normal to get small amount of oil through the breather pipe
be honest why would you bother to swap filter round as don't you have it serviced once a year , so should just get changed any way
Post #423425 14th May 2015 10:10am
Renewing the air cleaner is a B service item so it's replced every 2 years or 24k. I just thought that if you follow this, then swivelling it after 12 months would give you a "new" clean face on the output side.
Post #423428 14th May 2015 10:53am
gilarion
That sounds sensible to me. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #423430 14th May 2015 11:02am
K9F
Fit an oil catch can like a Provent perhaps? If you go through life with your head in the sand....all people will see is an ar5e!!
Post #423453 14th May 2015 12:15pm
Provent is an option - but a little expensive & haven't people had issues with mounting it all in the confined space?
Post #423454 14th May 2015 12:17pm
K9F
As with yourself I have an XS and yes it was indeed a tight fit. There are also Provent copies about but a genuine one was £109 delivered (see thread below). I have cleared out my gallery but if you do commit just drop me a 'pm' and I can send you all the fitting instructions. Thumbs Up
http://www.defender2.net/forum/topic28919....p;start=30 If you go through life with your head in the sand....all people will see is an ar5e!!
Post #423455 14th May 2015 12:23pm
tatra805
Slovakia 2008 Defender 110 Puma 2.4 CSW Bonatti Grey
waiting for my pro-vent 200 to clear customs, should come in tomorrow
searched around and could not find cheaper (all in) than buying it in australia, company called sydneyfilters also on ebay, about 88£ delivered if i remember correctly.
Local MAN&HUMMEL dealer was 25 £ more expensive on a 100 model with a 4-8 weeks delivery time Shocked
Hope i'll have the place to fit it as i do have my webasto and airhose taking up space around the vent pipe
Thumbs Up
Post #423464 14th May 2015 12:45pm
LR90XS2011
or just vent the engine to atmosphere (via an oil catcher and filter) and plug the hole in the filter pipe, removes any chance of combustion gases oiling up your intercooler , turbo and egr, just fit the pipe back for the MOT. (all old cars / engines were vented to atmosphere and it is only emission regs that suggest you should do otherwise) DEFENDER 90 TDCI XS,
Post #423544 14th May 2015 4:54pm
munch90
some of the idea is that by venting engine to intake pipe is that the inside of the engine is under slight vacuum preventing oil leaks
if you have a weak oil seal air will be drawn in rather than oil leak out , so not really advisable to vent to open air
Post #423551 14th May 2015 5:05pm
LR90XS2011
Munch I would agree if you have a leaky old engine. However a leaking seal is actually better fixed than hidden by vacuum in the crank case. I agree a filter should be used, my 90 has run for about 5k without the pipe connected and the hole in the air box pipe blanked. I have a tdi separator as a catch tank and a small filter venting so far so good and no oil leaks (I am only at 13k miles) What I have not got is any oil ahead of the turbo from the oil in the combustion gasses, I'm happy to carry on testing this for everyone else. I would however have fitted the provent in preference if more space had been available as they are great bits of kit. DEFENDER 90 TDCI XS,
Post #423570 14th May 2015 6:33pm
munch90
you don't need a leaky old engine , rear crank seals aren't the best on tdci when new !
Post #423596 14th May 2015 7:39pm
LR90XS2011
will keep an eye on it, I'm assuming it was fine when the clutch was replaced about 400 miles ago by Guy Salmon DEFENDER 90 TDCI XS,
Post #423598 14th May 2015 7:45pm
BykerPete
United Kingdom 2014 Defender 110 300 Tdi CSW Willow Green
Similar problem but maybe a different cause?
I took the big hose off that goes into the turbo (the one that has the breather pipe coming off it) and found slight traces of oil there and also on the inlet side of the turbo. Not a lot of oil, more of a smear than anything - oil is also very black even though an oil and filter change has just been done.
Engine has done 16,500 miles.
Is this anything to worry about and what - if anything could be causing it?
Thanks in advance,
Pete.
Post #426884 28th May 2015 2:43pm
Pete - that sounds like it is working as it's designed to do. Pull your air filter and check to see if you have any oil on the clean side facing the output hose. That was my issue.
I also have a leaking rear crank seal, so any slight vacuum is not keeping up with that! The crank seal is being replaced...and I thing the ventilation hose will be vented elsewhere and blanked off from the clean side soon as well.
Post #426904 28th May 2015 4:43pm
