Home > Off Topic > Flail mowers
Lambley
United Kingdom 2006 Defender 90 Td5 HT Java Black
Flail mowers
After asking a few questions about strimmers etc - now for mowing questions -
I'm buying a property with a bit of land, I want to put some sheep on the 3 acre field but my wife wants to keep in for the dogs to run around in, and she'd like it kept 'nice and mowed'
So, would it be easy to attach a flail mower to the back of my 90 and give it a good mow every few weeks or am I talking rubbish - and if I am what's the best option for keeping it tidy?
Post #423116 13th May 2015 8:18am
d j hutton
England 2011 Defender 110 Puma 2.4 USW Orkney Grey
We have had sheep on our paddocks for a number of years and they keep it better and shorter than the lawn! so why not divide in half with a moveable wire fence (maybe electric) and rotate some sheep around so they keep it short and the dogs can use the half that the sheep are not on. That way you both get what you want and you get to keep the money for a mower for something better. You'd probably want to rotate sheep anyway after worming , so that sounds like a win/win.
Don't know much about flail mowers I'm afraid, but I have a sit on lawn tractor/mower which never got much use while the sheep were around.
dj 1989 200tdi 90 csw
2011 110 usw Orkney grey
Buy British 🇬🇧
Defender Clothing Designs available at http://www.rangesports.com/acatalog/Defender-Stuff.html
Post #423124 13th May 2015 8:51am
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
You could run a hydraulic one, but you would need the pto fitted to your gearbox,
These do turn up on eBay from time to time.
Although can be an expensive option by the time you have rigged up and found a flail that's compatible.
I have a rear mounted pto on one of my series 1s
A lot of people still use them for light topping,
You would be better of buying an all in one paddock topper with the engine built in on the deck, that way you can just trail it around with the land rover.
Widely available from agricultural dealerships.
In various sizes and HP.
Ian 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #423137 13th May 2015 9:52am
Happyoldgit
^^ Thumbs Up A self powered topper would be the answer but despite guards etc there's always a chance of something flying up and hitting the back of your pride and joy. Flail toppers, while being able to deal with rough stuff, are usually more expensive than blade machines. Blades cut so usually give a cleaner finish. TBH you'd be better off with an old tractor but not so old so as not to have a PTO, the range of second-hand implements available is vast and usually a lot cheaper than those meant for mini tractors. Mind you everyone and their cousin are usually on the lookout for a bargain topper at this time of year. Steve.
http://forums.lr4x4.com
Post #423204 13th May 2015 2:04pm
willy eckerslike
United Kingdom 2007 Defender 110 Puma 2.4 HCPU Keswick Green
Ride on mower would be cheaper than a flail mower, problem with sheep is dogs love sheep Censored and will eat it at every opportunity. Original Member Pie n Pea Club.
110 HCPU Tipper
Post #423207 13th May 2015 2:28pm
Mountain_man
Wales
There is a nice Flail mower with a donkey engine on it made in Ireland by Logic to tow behind a Quad. If they are safe behind a Quad I wouldn't worry about uising one behind a 90. They are not cheap but come up on Ebay pretty regularly
http://www.logictoday.co.uk/equestrian/pro...oppers/mfp
Post #423216 13th May 2015 3:24pm
Mountain_man
Wales
eg.
http://www.ebay.co.uk/itm/logic-mower-MFP1...35e9b71d69
But you would want a 5 foot one behind a LR
Post #423218 13th May 2015 3:25pm
gilarion
If you keep dogs with sheep and who will use the same land regularly check your dogs for ticks. I have sheep near my property and even though the owner treats his flock whenever my dogs cross the field they always seem to pick up ticks. Or as we call them round here vampire spiders Wink For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #423221 13th May 2015 3:38pm
smb
Or use it as an excuse to get a Series 1 and adapt it with a pto on the back. There was an article in one of the mags a while ago about a farmer/engineer who does everything cutting logs, ploughing, mowing, raking, etc with a Series 1. Ill try and find it and scan it over to you.
Post #423229 13th May 2015 5:06pm
Lambley
Thanks for the replies and advice, lots to go at and think about, I've been down to the local farming/garden machinery place and got some advice, but I don't really want to spend a fortune. I'll have to keep my eyes open on eBay.
I'll need a good mower, probably some kind of flail mower (the Logic one looks perfect, thanks Mountain-man), a long reach hedge trimmer, good strimmer and a chainsaw (got)
It's either that or get rid of the wife and get a dozen or more sheep Rolling with laughter
Post #423302 13th May 2015 8:47pm
Rudski
Had a logic 120 mower a while back towed it behind my quad, flail is a bit more for rougher ground, mine had a 12.5 hp Briggs and Stratton engine on top never failed to start, floatations tyres and cut the grass as good as any push mower.
Thumbs Up
Post #423305 13th May 2015 8:54pm
Rickydodah
http://www.ebay.co.uk/itm/finger-mower-/151676809999
This is an oldie but a goody and it is land wheel driven Rolling with laughter I started with nothing and still have most of it left!
Post #423318 13th May 2015 9:26pm
jst
good excuse to buy a tractor Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #423323 13th May 2015 9:38pm
Happyoldgit
Agreed, if you are buying land a tractor opens up a whole load of labour saving possibilities and be far more durable than a Land Rover. Steve.
Post #423339 13th May 2015 10:33pm
Mountain_man
Wales
5K would buy my tidy MF575 with front end loader. I could even throw in a topper Smile
Or buy yourself a ride on mower. I saw one going cheap recently Rolling with laughter
Post #423344 13th May 2015 10:53pm
