Home > Technical > 2.4 Puma clutch change
jst
so engine out
or gbox out
Gbox output shaft and friction plate and cover plate aside.
recommendations on what else to check or change whilst in there? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #421980 8th May 2015 11:36am
shaggydog
I think the slave cylinder is worth a shout as its within the bell housing unlike on older ones where you could get to it without splitting the engine and gearbox.
I could be wrong though! Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Self confessed mileage hunter Very Happy
Post #421983 8th May 2015 11:46am
munch90
if your going to do clutch as well as out put shaft , then its gearbox out ( transfer first then main box )
if you took out engine to do clutch then you would need to fit engine back before removing transfer box as there would be nothing to hold main box in , as main box is either held by engine or transfer box , there are no mounts on the main box itself
as s/dog says always do the slave at same time as clutch ( yes its inside bellhousing )
Post #421984 8th May 2015 11:48am
jst
thank you
where does the clutch bleed on the slave still?
may be doing the shaft before, just wanted to add it above before it was commented on. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #421994 8th May 2015 12:21pm
munch90
yes on the slave cyl where the clutch pipe joins , at about 10-11 oclock looking from rear of gearbox , flat sided plastic type thing ( hard to turn if pressure on it )
Post #421996 8th May 2015 12:26pm
It is also worth replacing the flow restrictor in the clutch hydraulic line (attached to the slave cylinder where the line exits the bellhousing). It is cheap, but if it is becoming blocked (which happens) it greatly exacerbates snatchy take up and driveline clonks and reduces drivability.
Post #422039 8th May 2015 3:12pm
jst
dont suppose you have a MPN for the restrictor please? Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #423007 12th May 2015 9:04pm
I believe that it is UUG500040 and costs about £25 to £30.
Post #423042 12th May 2015 10:14pm
jst
appreciated, thank you Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #423043 12th May 2015 10:15pm
TJ101
Box out,, Not a difficult job,, has to do that 08 green 90, before the Wales reccy !! California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #423053 12th May 2015 10:36pm
