Home > Td5 > Td5 engine/ driving question
td590brad
United Kingdom 2008 Defender 90 Puma 2.4 CSW Santorini Black
Hi all
I have a td5 90
After driving it for 5 mins or more and then coming to a stop (cause of traffic lights) the engine seem to shake the car for about 5 seconds then stops and puts over normally
Anybody had this or know anything about it ?
Thank you
Post #422503 10th May 2015 10:05pm
mk1collector
Had exactly the same thing and thought the engine mounts were on there way out. Does your engine make a chirp sound when you switch off too? Mine was the crankshaft pulley (or harmonic damper) on its way out, if you do a search on here for crankshaft pully or read this good description and fix if the symptoms sound familiar.
http://www.discovery2.co.uk/CrankPulley.html Ray
My build thread
Post #422530 11th May 2015 12:06am
Alextd5
United Kingdom 2006 Defender 90 Td5 XS CSW Bonatti Grey
Re: Td5 engine/ driving question
Td590brad wrote:
Hi all
I have a td5 90
Thank you
Post #654940 4th Oct 2017 7:51pm
gazman
United Kingdom 2003 Defender 90 Td5 HT Alpine White
Is it the emisions control? Mine dos it if I coast up to lights. I've read others have had similar problems 2014 - current ..... 2003 defender td5 90 (my car)
2009 - current .... 2005 zx10r
Post #654957 4th Oct 2017 8:21pm
lightning
Mine makes a chirp sound when l turn off the engine but it's just the aux drive belt, a bit of WD 40 silences the chirp for a short time.
The belt has been replaced which de-chirped it for a while but the chirp has returned.
l checked the tensioner which seems fine.
Post #655049 5th Oct 2017 8:27am
bankz5152
Can be high idle and low idle. Some do it more than others.
Post #655050 5th Oct 2017 8:29am
