Home > Technical > New owner's list of repairs - any thoughts?
Jonathan111
Hello all, wonder if anyone can advise, my local Land Rover specialist just carried out an inspection of my newly purchased 1998/300tdi 110 - I'm new to Defenders, so wondering which of the following I should prioritise, and which, if any, sound any alarms.....be great to get some perspective from experienced owners. Any guesstimates on costs would be good, too.
Some of them are obvious, but I put them down for completeness anyway. Many thanks in advance!
1. Colour of the vehicle has been changed
2. Has got recon engine
3. Rear wash wipe not working
4. Hazard switch not illuminating
5. LH side repeater not working
6. LHF Out Rigger needs welding
7. Rear cross member needs welding
8. LHR Front bush on trailing arm got play
9. Rear exhaust trail pipe corroded badly
10. T/box got slight oil leak
11. Engine got slight oil leak
12. Rear diff pinion oil seal leaking oil
13. LHF & RHF wheel bearings got play (May just need adjusting)
14. LH and RH swivel leaking and got slight pits on swivel ball ( may just be able to change the seals, until we start the job and have a good look at the swivel balls)
15. LHR hub cap leaking oil (just needs a replacement rubber cap)
16. Rear brake pads worn 70%
17. Fan switch faulty
18. No fast speed on the wipers
19. Battery insecure
20. Rear door dragging (may need door adjustment or the hinge pins and balls may need replacing, not expensive)
21. Drive belt got cracks ( needs new belt)
22. Clutch fluid was low( may just need topping up or possible a leak, would have to keep a check on this)
23. Driver door u/s ( steel section missing from door, may be able to repair)
24. Misfire when cold
Post #421999 8th May 2015 12:46pm
jst
the lights, wheel bearings and leaking swivels as a priority
then chassis welding
at least then it can be seen stopping and staying together Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #422002 8th May 2015 12:50pm
Jonathan111
brilliant, many thanks, should have mentioned, the garage said the oil leaks were top priority
Post #422005 8th May 2015 1:06pm
shaggydog
My thoughts for what they are worth.
have you any photos? Thumbs Up
1. Colour of the vehicle has been changed - not necessarily an issue unless the DVLA or your insurers don't know!
2. Has got recon engine - yay?
3. Rear wash wipe not working - not an immediate problem, possibly a fuse.
4. Hazard switch not illuminating - new switch can be had for less than £15
5. LH side repeater not working - suspect bulb easy fix definately a priority though
6. LHF Out Rigger needs welding - very high priority
7. Rear cross member needs welding - depending how bad ether patch or chop it off and get a new one.
8. LHR Front bush on trailing arm got play - easy fix
9. Rear exhaust trail pipe corroded badly - so is mine, avoid britpart but cheep and simple to replace Evil or Very Mad
10. T/box got slight oil leak - so does mine, just keep topping up
11. Engine got slight oil leak- from where?
12. Rear diff pinion oil seal leaking oil- if its a Salisbury rear diff may need to take advice from a specialist as what seal to use as there is a few - also worth changing input flange
13. LHF & RHF wheel bearings got play (May just need adjusting) - see 14
14. LH and RH swivel leaking and got slight pits on swivel ball ( may just be able to change the seals, until we start the job and have a good look at the swivel balls) not worth it, strip them and change the swivels for new ones and while your there may as well change the bearings
15. LHR hub cap leaking oil (just needs a replacement rubber cap) new rubber cap
16. Rear brake pads worn 70% - new pads
17. Fan switch faulty- shouldn't have a fan switch unless you mean demister - in which case new one
18. No fast speed on the wipers -may be ether switch or relay- recommend upgrading relay to one with an intermittent setting
19. Battery insecure- new clamp can be had for a couple of quid.
20. Rear door dragging (may need door adjustment or the hinge pins and balls may need replacing, not expensive) you've said it Thumbs Up
21. Drive belt got cracks ( needs new belt) you've said it Thumbs Up
22. Clutch fluid was low( may just need topping up or possible a leak, would have to keep a check on this) you've said it Thumbs Up
23. Driver door u/s ( steel section missing from door, may be able to repair) should be able to repair quite easily - get a quote while your getting the chassis done
24. Misfire when cold - unnusual in a 300 Tdi, try a new fuel filter and some injector cleaner. Also check injector spill off pipes are not cracked or loose letting air in (and leaking!)
Of all of those I would agree with JST as the priority.
Only other thing I would add is look at getting the timing belt changed as that will give you peace of mind!
As far as cost goes depends how skilled with a spanner you are as most of those jobs are fairly simple jobs but if your not they could add up to a lot of labor! Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Self confessed mileage hunter Very Happy
Post #422006 8th May 2015 1:07pm
Jonathan111
awesome, many thanks Shaggydog, very helpful, am getting better with the spanner, depends on the job
Post #422009 8th May 2015 1:21pm
K9F
As far as I can determine at least 12 of those on your list are potential MOT failures and should be addressed with equal priority. It really depends on your technical acumen how expensive it is going to be and how much time and inclination you have to do it as Shaggydog stated? Will you be doing the work yourself?
Spares are in abundance and cheap too. Do some Googling around the 'Usual Suspects' Paddocks, Rimmer Bros etc. Sounds like an excellent project. I am always sceptical of Dealers and Specialists and of course they would state the oil leaks are a priority....for them it will be biggest moneyspinners. It's an enthusiast or like-minded person you may need to cajole into assisting you.
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #422010 8th May 2015 1:21pm
shaggydog
What part of London are you biased? Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #422012 8th May 2015 1:34pm
Jonathan111
thanks very much for advice on oil leak repair/specialist advice, yes - I suspected as much. I am planning on doing as much as my competence will permit, no MOT til November, so got a bit of time, main priority is to keep it running, while ensuring I tackle the key repairs asap before they become unstable/dangerous, some I'll do myself, some I'll have to fork out for, the more info I have the better I'll be able to make a judgement call on which comes first and whether I or the garage does it, this is tremendously helpful, so cheers! Thumbs Up Very Happy
Post #422015 8th May 2015 1:38pm
Jonathan111
- hiya, based in E17
Post #422016 8th May 2015 1:39pm
jst
t box and engine oil leaks are not a priority
swivels are. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #422020 8th May 2015 2:03pm
steventheplumber
England 1987 Defender 90 200 Tdi HT Keswick Green
That list seems a very familiar one!
Post #422595 11th May 2015 11:35am
yostumpy
Obviously this particular station wagon has been neglected for a wee while Whistle . glad its found a loving home. Very Happy
Post #422761 11th May 2015 9:58pm
