Home > Technical > how do you? wire std heated seats up
jst
I have fitted some xs heated seats to a 200tdi, does anyone know, and would care to explain how I can wire them up so they work?
I am guessing a switched relay is all it takes, but what amperage do they draw?
Does it matter which way around the writes are connected to the plug on the seats, plus any ideas on the plug I would need to fit the plus already on the seats? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #421865 7th May 2015 9:25pm
TJ101
http://www.mobilecentre.co.uk/index.php?ma...cts_id=779
Or similar California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #421889 7th May 2015 10:40pm
MartinK
http://www.defender2.net/forum/topic17504.html?highlight=waeco
lots of contributors to defender2 have done similar...may help... Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #421927 8th May 2015 8:29am
shaggydog
Can't help you with the wiring I'm afraid but will keep an eye out for your progress as I must hold my hand up to thinking of doing the same Whistle
Where did you get the seats from? Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Self confessed mileage hunter Very Happy
Post #421951 8th May 2015 10:22am
jst
cheers Guys will have a look through.
i had some takes out from a new vehicle, i have more of them for sale in the relevant forum Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #421952 8th May 2015 10:25am
TJ101
http://www.defender2.net/forum/topic36866.html Very Happy California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #421959 8th May 2015 10:43am
K9F
The resistance is about 3.4 ohms so the current draw should be about 3.5 amps per seat.
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  If you go through life with your head in the sand....all people will see is an ar5e!!
Post #421963 8th May 2015 10:49am
