![]() | Home > Puma (Tdci) > Wierd issue and sometimes loss of power with Puma 2.4 |
| K9F Member Since: 12 Nov 2009 Location: Bournemouth Posts: 9610
http://www.defender2.net/forum/topic20334....+gauge+max
http://www.defender2.net/forum/topic21349....le+maximum If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
| Alexke Member Since: 03 Jan 2011 Location: Antwerp Posts: 113
thanks for your response ,
I already did some google searching and found those topics. I just checked the relays if they where loose and there was one which was a bit loose . it was the 3th one starting from the front of the car. is there a relay diagram of the defender ? cant find it in my owners manual. Discovery 4 SDV6 Landmark F31 320dA Msport xDrive LR Defender 90SW TD4 Stornoway grey 320d E46 E70 X5 3.0d Sold! FFRR TD6 - Sold |
| ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1864
Earth strap bulkhead to chassis under right hand footwell?
So im still having this issue ,
Dealer checked and did : earth straps connected extra earth to ECU Relay´s While reading the OBD2 they found CANBUS related issues also an loss of connection to the IPAC. I also found out that when I hit the top of my IPAC on the dash part of it , it immediately goes back to normal. So im guessing a loose solder joint or component in the IPAC. Dealer is suggesting a replacement for 380€ excl tax! I think im going to do this because I just want to drive the damn thing without troubles. What do you guys think? Discovery 4 SDV6 Landmark F31 320dA Msport xDrive LR Defender 90SW TD4 Stornoway grey 320d E46 E70 X5 3.0d Sold! FFRR TD6 - Sold |
| nickhodgson Member Since: 08 Dec 2009 Location: Zambia Posts: 174
Has your IPAC every been previously removed/changed/refitted? I would first check the connection at the back of the IPAC. It has a fiddly setup that can be broken if you are rough and then it will not hold the connector together well enough.
Cheers Nick 1995 300tdi Defender 90 P/UP 2011 Puma Defender 130 D/C 2000 300tdi Defender 110 P/UP 2015 Discovery 4 SDV6 HSE |
| zone30 Member Since: 07 Sep 2012 Location: Gent Posts: 669
I don't think it's that, but apparently the basic problems also occur when your radiator is full of dirt. Don't see the relation to the canbus problem, but worth a check maybe. Check both sides.
| ClaudeG Member Since: 24 Jun 2014 Location: Johannesburg Posts: 10
Alexke I had exactly the same problem. I had an Ultragauge connected to the obd port and disconnected the battery (both terminals) while working on something else. When I reconnected the battery the Ultragauge froze in a scanning mode and the truck acted exactly as you described.
To fix it disconnected the gauge from the obd port and reset the ecu (the ignition on off 6 times trick). This solved it. Then reconnected the Ultragaude as per instruction. Did you by any chance have your scanner plugged in while you disconnected the battery? Cheers Claude |
| carrotbay Member Since: 18 Aug 2013 Location: Northants, UK Posts: 707
I also had this problem a few times. I had a a wifi OBD2 dongle fitted to use with my phone. Disconnected the obd2 and haven't had the issue since.
Could also just be a coincidence but I changed the battery in the key fob at the same time. 2008 Defender 110 XS SW - M57N2 / 8HP70X |
Thanks for the reply´s so far!
indeed those cheap OBD2 readers are no good really , they also do tend to give the same error. But it does this even without anything plugged into the OBD port , so that's not the problem. Just bought the NANOCOM EVO 2 and immediately did some testing ! First I cleared all the faults that were in the ECU, and begin driving hoping the gremlin would show up. after testing the NANOCOM´s cool 87mph and 205R16 coding i did a 96mph run , I was impressed! After this I coded my tyres back to normal and after 10 minutes it began! while it was doing its thing I read the code out : FAULT 1 OF 1 ECU: Engine Management CODE:U0155 Lost communication with instrument cluster control module (INTERMITTENT) So thats the ENGINE ECU telling me it lost the Cluster . I also got an error that my Cluster ECU wasnt responding ! well well well ! awesome! So I do what I always do : hit the top of the cluster with a slight tap . And my Tacho was back ! Read the ECU´s again and got these : FAULT 1 OF 3 ECU: Instrument Pack CODE:U0100 Lost communication with engine control module/powertrain control module 'A' (PENDING) FAULT 2 OF 3 ECU: Engine Management CODE:P1643 CAN link engine control module/ transmission control module circuit/network malfunction (PERMANENT) FAULT 3 OF 3 ECU: Engine Management CODE:U0155 Lost communication with instrument cluster control module (PERMANENT) So clearly there is a fault in the cluster or wiring , but when I wiggle the wires of the cluster , nothing happens. Im thinking that there is an internal fault in the cluster (diode or chip) https://youtu.be/03RFVfyw-1g Discovery 4 SDV6 Landmark F31 320dA Msport xDrive LR Defender 90SW TD4 Stornoway grey 320d E46 E70 X5 3.0d Sold! FFRR TD6 - Sold |
| HardCharger Member Since: 03 Mar 2013 Location: Manila Posts: 824
I experienced my gauges going haywire once. Throw in some engine cut offs too. After trying to drive along with these under rough road conditions, the consistent light was the battery light. Pulled over to a safe side and took a look as I suspected that the battery terminals may have been loose or something, nope. They were tight and right but upon wiggling the wires holding the terminals I saw some sparks by the bulkhead. Apparently the battery clamps that hold the battery in place have gone missing! (Don't know who pinched them) So had to make due by jamming something in between the battery and they bulkhead and it solved the problems.
Got myself some proper clamps and all is now right with the world. I hope your woes are as easy to fix as mine. |
| All times are GMT |
