Home > Td5 > Door check-strap bolts |
Paddie42 Member Since: 24 Apr 2014 Location: Hamphire Posts: 230 |
I took the front door check-strap off to repair (part no. MWC5018). It is held on by 3 bolts.
The single 10mm bolt now doesn't fasten to anything. Is there a fixing plate behind the bulkhead that has come loose? And how do I get to it to check? Thanks in advance Paddie |
5th May 2015 11:48am |
