![]() | Home > Td5 > Clutch |
| theorangebandit Member Since: 03 Jun 2013 Location: Stowmarket Posts: 862 |
. The internet is always good for this type of thing and these videos could help you out
| Fatboy Slim Member Since: 04 Feb 2008 Location: Bridgend Posts: 1006
Long bit of splined centre goes towards the flywheel, so completely opposite to the way you think it should go. FYI if you ever do one in a Mercedes 814 truck they go the same way (useless info :oops: )
| munch90 Member Since: 26 Oct 2013 Location: guildford Posts: 3558
did you find what the problem was ?
| tazmarkuk Member Since: 24 Jan 2012 Location: Birmingham Posts: 134
No I didn't. I haven't had the time just yet. Will be having another look the end of the month as I'm out of the country from this weekend. However I do think I did fit the clutch plate the right way round. I'll let you know once I've had a look.
Thanks for asking. |
Hi, update on my clutch issue, the friction plate was the wrong way round..doh all good now, The servo on the clutch is amazing
