Home > Puma (Tdci) > EGR tip |
4th May 2015 3:28pm |
Forestman1 Member Since: 16 Apr 2015 Location: Sverige Posts: 13 |
Great Defender 110 SW S, 2011, Galway Green
4th May 2015 4:09pm |
There is 'limited' success with buying a single blank off E-bay. Two failures in the following thread....
http://www.defender2.net/forum/topic32966....=egr+blank Buy one and use it as a template and get 6 made with the following sizes....18mm, 16mm, 14mm, 12mm, 10mm and 8mm. Start with the 18, run with that for a few days then work your way downwards. If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
4th May 2015 4:24pm |
4th May 2015 4:51pm |
Alexke Member Since: 03 Jan 2011 Location: Antwerp Posts: 113 |
Mine does this for nearly 4 years always , never bothered me . Discovery 4 SDV6 Landmark
F31 320dA Msport xDrive LR Defender 90SW TD4 Stornoway grey 320d E46 E70 X5 3.0d Sold! FFRR TD6 - Sold |
5th May 2015 12:59pm |
