![]() | Home > Technical > Stability control |
| mikeh501 Member Since: 07 Jan 2013 Location: United Kingdom Posts: 1142
dont get that problem in mine
| Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6728
I do think it's a bit sensitive, the rebound on speed bumps makes the DSC graunch on my 90 but without the warning light coming on.
That said, when it activates during driving, I don't find it intrusive. Not like in the MINI which is a straight engine power cut 1988 90 Td5 NAS soft top
2015 D90 XS SW |
| grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4803
Had mine graunching on an off camber corner today, In the dry and not going very fast at all
| x-isle Member Since: 26 May 2011 Location: Midlands Posts: 1327
Over sensitive TC can be a sign that the oil/grease in the swivel hubs need topping up.
The slight extra friction can confuse the ABS sensor. I had it on mine a few years ago. Topped up with some oil and it solved it. I think that if your hear the ABS pump kick in but no light, the TC hasn't activated it's just the pump arming ready to activate when needed. Craig Rogers 2007 Puma 110 XS 2011 Evoque Coupe Dynamic Lux www.craigrogers.photography |
I hope not, mines only done 57 miles
| ken Member Since: 18 Aug 2009 Location: Banging Birds with my bitches !! Posts: 4328
Can sort that for you Martin |
| Clive Member Since: 21 Mar 2014 Location: Littleborough Posts: 467
I was just about to ask about the ABS sensitivity and thought I'd best do a quick search, hence arriving at this thread.
I too find it somewhat "over-eager", activating while going down a bumpy dirt track or taking a sharp bend, the really odd thing though is, sometimes when I hear the ABS modulator chipping in, the radio goes off momentarily at the same time I've noticed too that the radio screen brightness dips a little bit when I turn on the headlights or hazard flashers, checking the MY02 wiring diagram I found the earth return for all the lights and the ABS pump come back through the same earth header, K108, on the bulkhead, I've cleaned the connector and re-tightened the fixing bolt here but it's not made any difference, I also checked the earth connection from the battery to the chassis rail and gearbox, all nice and secure here. I'm just wondering if anyone else had seen the same thing and found a solution? |
| K9F Member Since: 12 Nov 2009 Location: Bournemouth Posts: 9610
'Jury Rig' an earth of your own from the disconnected earth of the lights only on K108 directly back to the battery and see if it makes any difference. If not it'll be the voltage drop of you switching the lights on. Not unusual persay. How old is the battery? If you go through life with your head in the sand....all people will see is an ar5e!!
Cheers for that, it's stopped raining now so I'll give that a try after I've done a few voltage measurements. I was wondering how many earth straps there are between chassis/bulkhead and engine?
I've no idea how old the battery is, I only just recently got this 90, it's just another thing on the ever growing list of bits to attend to. |
Sorted
Battery voltage was 12.6V after standing overnight, about 10V cranking, then around 14.6V with the engine running so seems reasonable. With the engine running and lights on, I checked from the battery negative terminal to the K108 terminal on the bulkhead and found around 0.5V between the two Checking further, I found there's an earth strap between the chassis and bulkhead at the bottom of the driver footwell, one end was loose and the other end, while tight, was fixed with a bolt going right through the chassis with a painted surface both sides I cleaned up all the connections and just for good measure, I added an additional earth strap between the chassis point and engine block using the starter motor bolt. A re-check on the voltage drop as above now shows about 10mV A quick test run and I'm happy to say all appears to be sorted, as an added bonus I'm no longer getting the overdrive lamp flashing at me all the time it's not engaged and the ABS / TC doesn't seem as twitchy as before. |
Good result.
| All times are GMT |
