Home > Puma (Tdci) > Anyone fitted a Alive decat and pipe?
Davie L
Scotland 2008 Defender 90 Puma 2.4 HT Orkney Grey
I've got myself an alive decat and wondering to get the old pipe and cat off down and out will I need to remove the cross member?
It's getting remapped Monday afternoon so I'd like to have it fitted before then.
Davie
Post #420510 1st May 2015 9:10pm
jomara
Scotland 2014 Defender 110 Puma 2.2 XS CSW Santorini Black
Hi Davie
This thread might help:
http://www.defender2.net/forum/topic26422....pe+fitting
John Thumbs Up 2014 110 2.2TDCi XS Station wagon - GONE
1971 Bowler Tomcat 88 4.2 V8 Auto
2022 110 D250 XS Edition - GONE
2024 110 D250 X-Dynamic HSE
Post #420519 1st May 2015 9:52pm
You will need to remove the crossmember unless you are prepared to cut the old pipe.
Removing the crossmember is easy - four bolts each side, and a biff from a hide mallet to knock it out. You can also copperslip the bolts and contact surfaces before putting it back, and you will probably need the mallet to help put it back. So many jobs on the Defender (propshaft, t-box flange, exhaust, clutch etc) are made easier with the crossmember off that in my view it is worth getting practised and keeping the bolts greased. With practice it is probably 15mins to remove, the same to fit. Taking it off can easily save half an hour on the job.
Post #420526 1st May 2015 10:19pm
K9F
I unbolted the front propshaft too on removal, the catalytic converter is the size of a small emersion heater and is a tight squeeze if you want it out in one piece. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #420540 1st May 2015 11:04pm
SimonDavies
Wales 2010 Defender 90 Puma 2.4 HT Zambezi Silver
Yep, same here. Removed both the cross member and the front propshaft.
Post #420553 1st May 2015 11:44pm
Rakthi
2011 Defender 110 Puma 2.4 HCPU Stornoway Grey
I cut the old pipe with a reciprocating saw. Took about 2 minutes. Couldn't get the cross member to shift. And like K9F already mentioned, you have to unbolt the front propshaft. I also had to remove the left rear mudflap and holder to get the original exhaust pipe out.
Post #420558 2nd May 2015 1:27am
Fifth Horseman
Using a bottle jack and a couple of blocks of wood you can spread the chassis legs slightly to aid removal of the crossmember.
Post #420569 2nd May 2015 6:21am
pannawonica
Australia
I used nickel anti seize on the bolts and a FBH too remove! Got too get me one of those dead blow type! Very Happy Thumbs Up
Post #420993 4th May 2015 2:34am
