![]() | Home > Technical > Rear suspension bushes |
| ericvv Member Since: 02 Jun 2011 Location: Near the Jet d'Eau Posts: 5817
Yesterday at the tire fitters I took a picture of one of my rear suspension bushes. Picture was taken when truck was lifted off the ground.
Is there some play visible, or is that just normal? Truck has done 74k km, zero off-road, so all gentle road driving, 99% none or light loads. Do I need to do something here, or leave it as is? Thanks advise. Eric Click image to enlarge You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
Thanks Munch for that advise. Now that the truck is back on its feet, I have tried to rock the shock in all directions and can only make the protectiv cover which seems around the shock move a bit. Zero movement of the shock itself on the bushes.
Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
| custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21029
Put your hand on it, rock the body and see how it feels. If it feels solid it's fine.
If there is any sort of tap or movement you can feel it's going. I usually find the OS usually gets worse first |
Steve, so I used a voluntary SVX rocker..... Madame herself.
All feels solid like concrete down at those bushes on both sides, nothing moves or taps at all. Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
| Anderzander Member Since: 08 Feb 2011 Location: Lancashire Posts: 1000
Eric
Did you rock the body or the body of the shock ..... ? It's the shock body you want to move. |
| nitram17 Member Since: 08 Jun 2014 Location: newcastle Posts: 2261 |
Eric what paint is on your chassis.......looks good is it oem or aftermarket? |
Madame rocked the truck itself while I was feeling the top of the shock to feel possible movement. But I myself tried to rock the top of the shock, and no movement at all there either... Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
As to paint, only the standard paint from Land Rover. What you see is the Dinitrol. After 3 years it still looks about the same as when it was newly sprayed on as per below picture. Dinitrol will be redone this spring by the way. Click image to enlarge Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
Sounds like there is no problem there then, believe me you'd tell from the movement if there was.
Euuuh... Dino juice? And what's with my welds? Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
Sorry for the late reply eric............ I had not noticed your comment...Dino is short for dinitrol and I was commenting on the great quality of welds on your chassis attaching ancillary items...........mine were covered in surface rust..........yours look great and i think my chassis must have been outside in the rain before assembly. .............................They also had a nerve to put a checked/pass sticker on it!
Click image to enlarge |
| All times are GMT |
