![]() | Home > Technical > Does anyone know what thread this is? |
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3347 ![]() ![]() ![]() |
Hi Guys,
I am looking at making up a fuel pick-up point for my Webasto for the up coming cold and chilly summer months ![]() Does anyone know what thread this part is? I imagine it is some sort of pipe thread but I want to know so I can get a fitting bought then machine a hole through the middle so I can drop a fuel pickup pipe down it. Unless anyone knows of a better way of doing it? Pipe in question is on a 200Tdi metal fuel tank. ![]() Click image to enlarge Red arrow ![]() As always all suggestions and helpful comments welcome! Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197 Self confessed mileage hunter ![]() |
Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1750 ![]() |
That is a blank fitting for the bare tube on the tank. Possibly M8 thread? It will only be any good if the pipe goes down inside. It maybe only a breather type pipe.
Is your engine fuel supply taken from the other side via the sender unit ?? http://new.lrcat.com/#!/1228/20326/20390/1598/21273 |
Thats the plan to make make a plug fitting which has a pipe on the inside which will go down into the bottom of the tank to pickup fuel
![]() The supply and return goes ontop of the tank and I'd rather not play with them as they are notoriously brittle on older trucks. I want to try and keep the webasto fuel system as separate as possible from the engine fuel system to minimise on reliability issues for both items. Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197 Self confessed mileage hunter ![]() |
I didn't know they had them munch?
Where would that be on the filter? Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197 Self confessed mileage hunter ![]() |
im not 100% , but have you got a pic of filter housing
isn't it the screw on filter type some filters have arrows on to showing which are ins and outs |
yes your correct screw on type
![]() I don't have a pick but I have done a quick google search and yes I think your right! Do you think it would be ok to fit another banjo bolt with a pipe to feed the webasto? I can put in a non return valve which should stop any air issues? If yes what do I need to buy? Or would it be better to go straight to tank? Sorry for so many questions ![]() Self confessed mileage hunter ![]() |
you have a lift pump on a 200 tdi so filter is fed from the pump , could this be a problem ??
has anyone done it , ie fed heater from filter ? someone maybe along later who has are you having the heater running without engine running ? |
With my 110 my sender is on the l/h side. I was going to swap with a sender that has a pickup pipe as well such as AMR1495
http://www.ebay.co.uk/itm/LAND-ROVER-DEFEN...1140361578 |
It could be a problem, in all honesty I have no idea
![]() Here are the pics of the filter housing ![]() ![]() Click image to enlarge Success it does have a unused feed point ![]() ![]() Click image to enlarge ![]() Click image to enlarge Bad news is it looks like its an inlet rather than a outlet. So I think its back to the fuel tank for answers? I want to use it as a block pre-heater so have it running without the engine running, having said that would be good to be able to run it as a supplementary heater. Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197 Self confessed mileage hunter ![]() |
Ohh good spot Romadog
![]() Will have a look but from memory the plug looks different. Will report back ![]() Self confessed mileage hunter ![]() |
Bother!
Looks like the pickup is on that side already. ![]() ![]() Click image to enlarge ![]() Click image to enlarge Looks like ether pickup goes in the side and return comes in the top, or vice versa. Hummm. I don't really want to drop the drop the tank for the purposes of "having a look". Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197 Self confessed mileage hunter ![]() |
eBay Item No. 271310141294
Something like this , in through the sender |
Looks interesting, would you have to remove the existing one sender? Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
The ones ive seen fitted in the ambulances we do , looks like you take the sender out , drill hole in sender , fit pipe with nut on inside to hold pipe tight , refit sender , of course making sure its sealed and pipe goes down in to diesel
personally never fitted one so all guess work , but must come with fitting instructions to follow someone on here must have fitted one ! |
