Home > Puma (Tdci) > Water in air filter of 2013 PUMA?
Floppy
Australia 2013 Defender 110 Puma 2.2 SW Zambezi Silver
Hi guys - I have a 2013 Puma and was recently driving when the engine light came on and I noticed I had limited power. It was raining very hard when this occurred. The engine sounded fine and idled well but I could not get revs. I crawled the car back to my local LR dealer who has just informed me I had water in my air filter? This is a surprise to me as I haven't been through any water deeper than about 12 inches?? I don't have a snorkel fitted though I do live in a pretty wet climate with quite a few very heavy down pours over the summer?? Can anyone please tell me how water may have gotten into the air filter? Any suggestions would be greatly appreciated as the dealer seems convinced I have been taking it through deep water??
Post #420072 30th Apr 2015 4:38am
If you've not been wading, the water must have been sucked in
Open your airbox up, at the bottom there is a drain hole, make sure it's not blocked
Post #420078 30th Apr 2015 7:25am
Floppy
Thanks mate - I'll do that! The dealer has since replaced the filter but didn't mention anything other than deepwater crossings?
Post #420081 30th Apr 2015 7:31am
munch90
air filter box lid not fitted right ?
Post #420095 30th Apr 2015 8:33am
AlanH
Australia
That's exactly what I was thinking Munch90. Same thing happened to my 2010 Puma and the lid hadn't been fitted under the back clips allowing water ingress which ruined the filter. Main stealer job of course. Twisted Evil
To check take off the blank cover on the wing and shine a torch up there with a small mirror and if you can see filter material it's not fitted right.
To fit correctly you can either push the replacement filter element right down into the housing then slide the top back on or do as I do:
Fit filter into top cover and while standing alongside the left wing bring it towards you with the far end tilted up, feed it carefully underneath the aircon hose and keep gently pulling it back towards you.
The last few leaves of the filter will need to be pushed back towards you but once they're in the filter lid will drop down and you'll find it's secure under the back tabs and can then be clamped down with the front clips.
I think most of the people they use here in Oz are either young unsupervised apprentices or refugees from unspeakable places who've never worked at any thing let along on modern vehicles.
Can you call a Deafener modern?
Hope this helps.
AlanH.
Post #420098 30th Apr 2015 8:49am
Pressure washer used around air vent?
Post #420204 30th Apr 2015 4:14pm
AlanH - similar technique but not sure why you put the filter in the lid - it works fine on mine with the filter in the base which means it's not proud of where the lid slides across.
Post #420225 30th Apr 2015 5:59pm
Floppy
Thanks all for your suggestions - I picked the car up yesterday and when I finished work it was raining again (though not as heavily). I made it to the exact same spot (about 5km from my office) when, you guessed it, same engine light and no power?!? Its back at the dealer now?? I will call and suggest poor fitting filter cover as you guys have also suggested! Will let you know how it goes?? At least they now know I wasn't driving though any flooded rivers!!
Post #420327 30th Apr 2015 11:48pm
wmca
Australia 2009 Defender 110 Puma 2.4 SW Stornoway Grey
Water in air cleaner element
2008 Puma, I have the same concern, after a pressure clean, did it twice to prove it, I have a snorkel and am to investigate further, seems to be sealing, but will do the check through the plastic bit on top of guard as advised by previous post. WMcA Brisbane Australia
Defender 2.4 Puma 2009
�Airbags! The other vehicle is my crumple zone!"
Post #420332 1st May 2015 12:11am
tuesdayfox
you guys must be from sydney.
the puma air duct is not sealed.
so water can sucked into the engine
I have done my airbox mod and always use pressure washer in the engine bay and never had a problem- that is if you make the air duct water tight
Post #420333 1st May 2015 12:24am
wmca
Water ingress air cleaner 2008 puma
Thanks for that, as soon as it stops raining I will check out the whole thing again must have missed something. It is a little late in UK, 0030hrs to be on the nett! WMcA Brisbane Australia
Post #420334 1st May 2015 12:31am
Floppy
Thanks for the suggestion - how do you make the airbox watertight? I have just returned from the dealer and it was water in the air filter again - surprise, surprise!? At least they no longer think i was driving it through rivers between me picking the car up and leaving work!
ha - Sydney no, northern NSW....just about to get another solid east coast low weather system (mini-cyclone for other readers!!). >200mm of rain forecast!!
Post #420341 1st May 2015 2:02am
